Upgrading my old PCS rig to a new PCS Rig
Dxryl
PCS PRISM TG WHITE ARGB MID TOWER CASE
Promotional Item
16GB NVIDIA GEFORCE RTX 4070 Ti SUPER - HDMI, DP, LHR
Graphics Card Support Bracket
PCS FrostFlow 360 Series ARGB High Performance Liquid Cooler
ONBOARD 2.5Gbe LAN PORT
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 2PM)
FAST TRACK 5 WORKING DAY DISPATCH
Welcome Book
PCSpecialist Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
PCS Trade Pack - New 2023
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/9R3MnQbgEh/
Any recommendations to change?
Looking a machine that will run most games stable and good along with occasional streaming mainly play survival games, extraction shooters, GTA RP and MMOs. This is based of a build that did have the AMD 7900 in it but I wish to stay with a nvidia card
EDIT: My budget is around 2200 pounds
It's their by default and would get removed before purchasing, windows defender is good enough for me :)
You'd be surprised the number of folks who don't remove it, and then suffer with the problems it causes, which is why when spotted in a spec its advised to remove, and yes defender does a great job at a great price(y)
Dxryl
That’s not showing as a model, are you sure that’s correct? Have you got a link to it?
This monitor here for main display
Appreciate ya bud
Dxryl
That monitor is going to quite severely restrict any modern build, would be worth thinking about upgrading that, technology has moved on so fast, the refresh rate is going to bottleneck any system at 1440p
Yeah upgrading the monitor is on the to do list but just putting priority on the rig itself
Yeah, absolutely.
There are a couple of areas that needed increasing to get what you'd posted up to par, this is it reconfigured, it's slightly over budget, but you'd be heavily compromising on important areas that would affect performance and upgradeability (case, cooling and PSU) if you didn't.
CORSAIR iCUE 4000X RGB TEMPERED GLASS MID-TOWER ATX CASE - WHITE
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
LED Lighting
2 x 50cm ARGB LED Strip
1 x 120mm PCS Black Case Fan
Microsoft® Edge
Price: £2,252.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/MMdPnRs4aF/
Dxryl
Yeah, absolutely.
LED Lighting
Microsoft® Edge
It's funny I was making some changes to the build itself and I changed the CPU cooler to the corsair H100x but didn't change power supply but with these changes I am happy and I have ordered it today :)
You understand that not upgrading the GPU means you may have to completely replace it (which basically means a full system rebuild) when it comes to upgrading the GPU?
It's not worth scrimping on the PSU, it's often overlooked and is incredibly important to the build.
Dxryl
Sorry my current build is a 2060 SUPER which I am now upgrading to this unit as you posted, are you saying I would not be able to replace the GPU in this build or upgrade?
I am hoping the machine itself with get 3-4 years just like this 2060 SUPER rig has gotten and probably going to be my last and biggest upgrade for a very long time! recently married and talks of kids are coming about so I may have to be buying them consoles or computers instead lol!
If your current machine is only 3-4 years old, why are you replacing it already? The whole point of a custom PC is that you can upgrade it or was it a cheapy off the shelf? For any properly designed PC you're looking at a 7 - 10 year lifespan with a couple of gpu upgrades in that time. These days it is nearer 10 years as you can significantly upgrade the processor.
You'd be able to replace it but you'd be limited to the wattage of the PSU which is fairly low. So you'd be able to replace it, but you'd likely have to downgrade the tier to fit within the 750W GPU as new cards will use more power at the same tier.
GPU TDP's have doubled over the last 2 generations, plus the recent reports are that next generation will use even more.
Plus with new GPU's you have to account for transient spikes, which the configurator doesn't, that's why the PSU was set as 1000W, that's the minimum you want to go at this level
Dxryl
The intel i5-9600K just doesn't seem to be keeping up with what I am playing, I get stuttering and input delays from CPU processing being like 99% on majority of games I play and I would rather at this point of age just go for a full new rig and pass this one down to my partner who will be using it for less demanding games.
I was hoping with this build that I do get that 10 year life span from it by swapping out parts if needed but I am not much in the way of upgrading/replacing what is in there and would rather upgrade the unit.
I very much doubt it's the CPU causing a bottleneck, if it’s at 100% it’s because something’s not right, at 1440p theres no way the load should be that high, it's more likely the GPU (which was never a 1440p GPU anyway) and perhaps software issues. In my opinion, it's pointless replacing it, just troubleshoot it and correct it, that's the entire point of a custom PC.
But if you're handing it down then I guess fair enough.
But if you're buying a decent custom with the intention of upgrading it, you need to design it for those upgrades, and a huge part of that is the PSU, it's not worth scrimping on. A 750W would unquestionably need to be replaced which is a pointless expense as well as requiring a rebuild, in which case if you have the knowledge to do that then don't buy a system integrators product, build your own, you'd get far higher quality components.
But assuming your current build is suitably designed, you may get just as good performance plus be able to afford a proper monitor by just upgrading rather than buying entirely new where you'd still need a good £500 to get a suitable monitor.
