Upgrading end of June.
WayPow
Hello,
I am upgrading from a i5 6500 and gtx 980ti at the end of the month as some games are not running as smooth as i would like (a lot of frame drops and stutter on COD warzone and in VR), does everything in this build look OK? do i need a different case, extra fans or a different cpu cooler? im using a 1440p monitor but would like to future proof a bit. Thanks.
NZXT H511 MID-TOWER GAMING CASE (BLACK)
Intel® Core™ i9 Eight Core Processor i9-9900K (3.6GHz) 16MB Cache
ASUS® ROG MAXIMUS XI HERO: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
11GB NVIDIA GEFORCE RTX 2080 Ti - HDMI, 3x DP GeForce - RTX VR Ready!
NOT REQUIRED
2nd Storage Drive
NOT REQUIRED
LED Lighting
2x 50cm RGB LED Strip
ASUS STRIX Soar 7.1 PCIe sound card
Standard Build - Approximately 15 to 18 working days
Price: £2,879.00 including VAT and Delivery.
If the budget is there for the 2080Ti then it's definitely worth it IMO. It depends on the VR headset though, to make use of it you would need the Vive Pro or the Index.
If it's any other headset I would probably opt for the 2080 Super, pocket the difference and put it towards the 3080 or 3080 Ti when it comes out.
