Hi guys,
As i have said in another thread (unfortunately no responses - i think i posted it in the wrong area of the forums. Mods please remove my last thread as it is much the same as this one) I managed to spill some water on my PC a few weeks ago. I have decided to use this opportunity to have a bit of an upgrade. I am fairly sure it is my motherboard the is damaged from the water damage, but I can't be sure that the graphics card isn't damaged as I am getting nothing on my monitor whether I have it in or out.
My current build (which was built 4 and a bit years ago) is this:
Intel® Core™i5-2400 Quad Core (3.10GHz, 6MB Cache) + HD Graphics
ASUS® P8H67-M LX SI: MICRO ATX MAINBOARD, LG 1155, SATA 6.0Gb/s
1280MB NVIDIA GEFORCE GTX470 - 2 DVI,mHDMI - DX® 11, 3D (Special Offer!)
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£78)
INTEL SOCKET LGA1155/1156 STANDARD CPU COOLER
ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD (£17)
USB Options -
I am planning on buying the following parts:
Intel Core i5 4690K Processor (3.5 GHz, 6 MB Cache, LGA1150 Socket) - £183
Gigabyte Z97P-D3 Intel LGA1150 Z97 ATX Motherboard (4x DDR3, 4x USB3.0, 10x USB2.0, GBE, LAN, HDMI) - £64
HyperX FURY Series 8GB DDR3 1600MHz CL10 DIMM Memory Module - Blue - £27
Total - £275
I am praying my GPU wasn't damaged by the water as u don't have the money to buy i new one, but if i do have to I am thinking of getting a GTX 960 after my next pay day.
Questions:
- Am I getting good value for my money? I am pushing my budget at £275..
- If I replace my MBoard and Processor, will this resolve any issues caused by my previous processor (Sandy Bridge had issues after they were released, something to do with degrading PCI ports)
- Is my old 650W PSU going to be enough? Will it still be enough if I have to buy a GTX 960?
- If my GPU is damaged, would this potentially cause any damage to any of my new parts when I power up? I do not have another PC to test it in..
I am going to order these bits today probably so i would appreciate quick responses so I can have some comfort knowing I am not wasting money
Thanks in advance guys
USB Options -
Total - £275
Questions:
