What can you upgrade with the upgrade service?
Random_Matt Bronze Level Poster Dec 25, 2013 #3 keynes said: Once you log in it shows the options available. Click to expand... Will not be buying till early January, just wondered if you can upgrade gpu's when new ones come out.
keynes Multiverse Poster Dec 25, 2013 #4 Depends on what you are buying. You can search on the forum from previous threads. For desktops yes for laptops depends on the chassis and whether or not a bios update is released to support newer GPUs .
