Update or leave.
carlos726811
As the title says. Shall I update my motherboard and other stuff in my armoury crate or just leave as it is?
B4zookaw
I wouldn't suggest using atmory crate for updates. Always use Windows update.
I don’t think Windows provides these updates, they’re updates to Crate itself.
Carlos, find out if the updates fix any issue you’re having. If everything is working fine, leave the updates. Crate can be buggy at times (I’ve completely removed it from my system), so if it ain’t broke, don’t fix is my advice
