Update advice
steventurnerpro
Hello,
I bought a custom build desktop from PC specialist previously. It has done the job required however I now find it is lacking on my needs.
Here is the specs of what I bought
CaseInWIN 303 MID TOWER GAMING CASE
Processor (CPU)Intel® Core™i7 Quad Core Processor i7-7700 (3.6GHz) 8MB Cache
MotherboardASUS® PRIME Z270-P: ATX, LG1151, USB 3.0, SATA 6GBs
Memory (RAM)8GB Corsair VENGEANCE DDR4 3000MHz (2 x 4GB)
Graphics Card3GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP
1st Storage Drive250GB WD Blue™ 2.5" SSD, SATA 6Gb/s (upto 540MB/sR | 500MB/sW)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
Processor CoolingCoolerMaster Hyper 212X (120mm) Fan CPU Cooler
Wireless/Wired Networking10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
Operating SystemGenuine Windows 10 Home 64 Bit - inc DVD & Licence
Windows Recovery MediaWindows 10 (64-bit) Home DVD with paper sleeve
Office SoftwareNO OFFICE SOFTWARE
BrowserGoogle Chrome™
MonitorSamsung LS24D330HSX/EN 24" LED monitor
DeliveryPCS EXTRA-CARE DELIVERY TO UK MAINLAND - MON-FRI, PRE-NOON
Build TimeStandard Build - Approximately 10 to 12 working days
Promotional ItemFREE Halo Wars 2 with select INTEL® CPUs!
Promotional Code J33DRH3FKQ3M
Promotional ItemFREE FOR HONOR or GHOST RECON: WILDLANDS with select GTX 10 Series GPUs!
Promotional Code UDHX-VBHA-NURX-RABX-WBBF-PJMP
I play online multiplayer games like COD Warzone on my machine however it does not run smoothly unless I have most settings on low. It also lags a bit if I try to stream my gameplay or my screen.
I want to be able to play with all settings on high, and be able to stream and have plenty of power leftover. I want to be able to have programs open and running, while gaming and streaming without causing issues with performance.
I obviously made a mistake on disk space too.
How would you update this build to solve my problems above and future proof my machine?
Kind regards
Steven
steventurnerpro
Ok. I would be interested to hear what others think too.
If it does turn out that a new system would be more economical - I would love some suggestions. I want a system that isn't going to leave me limited. I want to be able to game, stream the game play and have programs running in the background that I can run on my second monitor. All without any lag or issues.
What monitor are you pairing it with, what resolution and refreshe rate? Is it just the one in that build?
For gaming, there wouldn't be a problem with that build, but it's not suitable for streaming as well, you'd need a new build for that.
What's your budget for a new system?
steventurnerpro
Well, I know i need a better monitor. for suuuure. I am not getting the benefit of PC gaming playing on low settings and crappy monitor.
In an ideal world I could update my existing kit to get top specs and performance. I wouldn't like to spend a fortune but I am in a position that I could if I needed to.
Without knowing a budget it’s impossible to advise
steventurnerpro
I don't understand what the problem is.
I am smart with my money and dont want to overpay for a system I don't need. Thats being said I want the best value I can get.
I have advised I have no upper limit. I am just looking for recommendations on the best value upgrades that will meet my desired requirements. I am sure you wouldnt be recommending me a 10k+ machine if my budget allowed it - if I didnt need it based on my needs?
Depending on budget depends on what quality of system you get, weather it's 1080p, 1440p, 4k, and what refresh rate, 60Hz, 144Hz, 240Hz, then you need a screen to match, if you're looking at 4k, that's between £600 to £1200, if you're at 1080p that's between £120 and £300.... there are too many variables to work towards without knowing a budget ceiling.
We strictly request this because we've been here many times where we build a system and then the person says "but can't I cut the cost somehow" and it just wastes everyones time.
If you're truly looking at no budget limit then we'll do a 4k 144Hz or Superwide system, but that will set you back many thousands of pounds.
Just working out if you appreciate what you're saying when you say no upper limit.
