This is an intermittent issue I'm having with my Octane VI i7-8700k w/ RTX 2080, ordered last summer, which has otherwise been excellent or even better in all respects.
For most of the time I use this laptop, temps are very satisfactory. Idle/net browsing temps for CPU is low 40s and GPU the same or lower. Under load, in the very demanding and poorly optimised Kingdom Come: Deliverance, CPU can peak at 85C under sustained play while GPU peaks at 75C or less. This is with fans set to 5% offset in Control Centre 2.0, so in theory it could perform even better if I wanted to deal with more fan noise. Considering that sales indicated this configuration might frequently hit 100C under load, I've been beyond satisfied.
However, now and again, usually after I haven't used the laptop for gaming in a few days, I'm faced with a situation where the fans don't seem to be handling the temps at all. CPU fan and temp behaviour remains the same under idle and load, but GPU will quickly creep up and beyond 75C on the KCD main menu alone, then be set to go much much higher, probably 90C or more, unless I handle it myself by tabbing out and dragging the fan offset to a much higher value or setting fans to maximum. Either of these measures works to bring temps back under control, but the fan noise difference when the fans finally kick in makes it obvious that they weren't really doing their job at all at the original offset value.
I've been faced with this problem about 3 separate times now and each time I seem to be eventually able to 'jog' the system out of this behaviour by fiddling with offset values or changing back and forth between Automatic vs Custom fan profiles in Control Centre. Once I do this enough times, or perhaps due to some other unseen change I'm unaware of, 5% fan offset will once again become perfectly sufficient for the fans to keep games at around 75C peak. One time I was able to fix it via a full power-down, 2 minute wait and then restarting (simple restart does *not* fix it). I'm unsure what causes the change in behaviour in the first place.
I've updated CCC 2.0 to 1.0.78 via the Clevo website and it hasn't changed this pattern. Changing nVidia drivers makes no difference either. I seem to have a few ways to jiggle the fans back into behaving properly when this problem occurs but none of them are ideal or reliable. For instance increasing the offset to around 40% makes them louder under idle and also doesn't seem to keep them as adaptable at higher temps, so the GPU still peaks a few degrees higher when I'm experiencing this behaviour.
Anyone have an idea what's going on or have a better idea of what the culprit might be? Any perceivable benefit in trying CCC 3.0? Obviously I'm not eager to RMA or re-paste a system that seems to be running very well most of the time, outside what might very well be a software utility problem.
Specs:
Octane Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080) + G-Sync
Intel® Core™ i7 Six Core Processor i7-8700k (3.7GHz) 12MB Cache
16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 2080 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
2TB SAMSUNG 970 EVO M.2, PCIe NVMe (up to 3500MB/R, 2500MB/W)
W10 pro.
Specs:
W10 pro.
