Unable to access forum via wifi
agh55
Hi, I can't access pc specialist forum via home hub and wifi. When I take the link from the main site or put the full address in to the browser I get a message oh dear , a few lines of possible problems and then 20 seconds later I get taken back to main site. Have tried the following with no luck,
Changed browsers ie edge, ie11, Firefox and chrome
Tried iPhone and iPad over wifi. When I switch off wifi and use the 4g network I get access
Changed hub , can't access forum.Using BT hub 6
Disconnected my desktop from the hub, still can't access via wifi
Basically it's a problem with BT's dns servers, they often fail and I'd highly r commend using googles instead as they're much more reliable and faster. I'm on BT and sporadically had the same issue so swapped out the home hub for an Asus router.
The home hubs won't allow you to set a custom dns.
