Umm.. what do i need to enable in the bios to allow for usb booting?
Insane.Pringle
I'm trying to boot off a USB pendrive but it's not working..
I have shifted (in bios) the usb to top of boot list and disabled secure boot but it's just sitting there after saying 'loading minirt.gx...ok'
Any other settings that need to be changed?
The distro on the pendrive is runtime-live v7.
Sometimes the boot order will show both the USB drive itself and also Partition 1 on the USB drive. You need to boot partition 1.
Nope lol.. it had a partition 2 which I chose after press F8. Same thing..
Gonna try a different pendrive
The tool you use to make the bootable drive (Rufus for example) must create a UEFI capable pendrive, an old MBR based drive won't boot.
Insane.Pringle
Currently using balena etcher. It worked but driveimage xml can't see the nvme drive lol..
Looking for another live distro that I can use to backup the nvme drive before I start using it
Insane.Pringle
Grr... I think my old computer knows there's a new pc in the house.. its pretty much destroying any usb pendrives/sd cards I turn into live usb pendrives!!!
Which is making is hard if not impossible to access the backup image of the new pc..which I need lol
