Ultranote V can't handle videogames :O ???
KFC man
So I bought a ultranote V laptop a while back and other than linux only working with a usb wifi adapter it's awesome!!! and the other day I decided to go and play minecraft so I did just that but the whole laptop shut off after 20 minutes of playing on low settings :O . I started it up again & it crashed again when booting up minecraft! I touched the laptop with my hand to feel how hot it was and it was super hot so maybe it overheat? idk I never even hear the fan so I doubt it even has a fan but idkkkkkkk. Can my laptop not handle videogames at all?!?!?! Please discuss & thanks for reading
Bhuna50
Post your full specs but the laptop you have listed Ultranote - is not classed as a gaming laptop by PCS - its a thin / light laptop so I expect the machine is overheating when you are trying to run processor / gpu intensive games (3d ones).
It also only has integrated graphics and no dedicated GPU so yes I guess its overheating as looking how thin it is as well, there is not a lot of room for or many vents on it to keep it cool.
It shouldn't be shutting down like that.
If you post your full specs from the order page, we can see what we're dealing with.
KFC man
Whoops sorry for not posting the specs but here they are!:
Chassis and display UltraNote-serie: 14" mat Full HD IPS 60 Hz 45% NTSC led-screen (1920x1080)
Processor (CPU) Intel® Pentium® 4 Core N5000 (1,10 GHz, 2,7 GHz Turbo)
Memory (RAM) 8GB DDR4 2400MHz SOLDERED (ONLY N5000 PROCESSOR)
Graphic card INTEL® HD GRAPHICS (dependant on CPU) - 1,7 GB Max DDR4 Video
RAM - DirectX® 12
1e M.2 SSD-station 256 GB ADATA SU800 M.2 2280 (560 MB/R, 520 MB/W)
Integrated memory card reader
Battery UltraNote Series integrated 36WH lithiumionbattery
Soundcard Intel 2-channels High Definition Audio + MIC/headset opening
Bluetooth and wireless WIRELESS INTEL® Wi-Fi 6 AX200 (2,4 Gbps) + BT 5.0
USB/Thunderbolt-options 1 x USB 3.1-PORT (Type C) + 1 x USB 3.1-PORT + 1 x USB 2.0-PORT
ULTRANOTE SERIES KEYBOARD
RAM - DirectX® 12
If you can post the FULL specs from the order page? There's a lot more to it than what windows will output.
