Ultimate Machine
brulei
Hi guys, very new and first post. I was just looking at this machine.
COOLERMASTER HAF 922 MID TOWER GAMING CASE
Intel® Core™i7 Six Core Processor Extreme i7-3960X (3.3GHz) 15MB Cache
ASUS® RAMPAGE IV EXTREME: INTEL X79, SOCKET 2011, R.O.G
32GB KINGSTON HYPERX GENESIS QUAD-DDR3 1600MHz X.M.P(8 x 4GB KIT)
3GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card
120GB KINGSTON HYPERX SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
1TB SEAGATE Barracuda SATA 6Gb/s HDD, 32MB Cache (7200rpm)
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£42)
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£159)
INTEL CERTIFIED LIQUID CPU COOLER FOR SOCKET LG2011
Fan Controller
NZXT Sentry 2 Fan Controller with upto 5 Fitted Case Fans
GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI-E CARD (£16)
Genuine Windows 7 Ultimate 64 Bit - inc DVD & Licence (£146)
None at the moment
DVI-D & HDMI Monitor Cables
2 x 2 METRE GOLD PLATED V1.4 HDMI CABLE (£15)
Surge Protection
6 Socket Compact 2M UFO Surge Protector + Auto Power Off Function (£19)
Cable Tidy
3 x JML 1.5M Zip Cable Tidy - Professional Cable Management (£10)
3 Year Platinum Warranty (3 Year Collect & Return, 3 Year Parts, 3 Year labour) (£135)
Price: £3,251.00 including VAT and delivery.
What do you think about it? I am a bit concerned that the graphics cards won't work together. Could you guys please confirm that for me and post any oppinions on it?
Thank you
Rakk
The Awesome
Why do you need so much memory, what are you planning on using this machine for? Are you doing a lot of rendering?
2nd Graphics Card
Those two cards will run perfectly fine together, you can probably also heat the house with them whilst you're at it :)
Very powerful, but if you can tell us what you're planning on using it for we can probably make some suggestions, cos there are very very very few reasons why you would actually need such a powerful machine :)
Music Guy123
Looks like a true beast! I would recommend upgrading to the haf-x case as it provides better cooling. Also, for the second HDD, I'd suggest a caviar black as they are very fast drives and the 2Tb is the same as the 1TB so would give you extra storage. Other than that, that is probably the most powerful pc I have ever seen posted here! Enjoy it!
brulei
I would be using it for Gaming mostly. I do want to future proof it as much as possible. I will use the case that you advised me along with the 2tb caviar black HDD. I might do some video editting on it from time to time for some rendering but nothing heavy.
It will be mostly gaming, and I am a bit embarrassed now due to the massive amount of overkill but I want to be boosting it like a beast.
Rakk
The Awesome
There is a difference between future proofing and complete overkill :)
If you want to be overkill with RAM for gaming then you can drop down to 16GB (which is still overkill in my books), you certainly will not need 32GB :)
Also unless you have specific needs for Win7 Ultimate you could drop down to Win7 Home Premium (which has a 16GB RAM limit on it).
mantadog
Superhero Level Poster
32GB of ram is HUGE, gaming wont touch 8GB yet let alone 32GB. Your dual 580's will probably be junk by the time you need over 8GB to game on really. I would strongly advise you to save the cash, if you want futureproof get 16GB as has already been suggested anything more is pointless.
brulei
Hey guys, thanks for all the info about this. How about this spec instead then? Does it seem better?
COOLERMASTER HAF-X FULL TOWER GAMING CASE
16GB KINGSTON HYPERX GENESIS QUAD-DDR3 1600MHz X.M.P(4 x 4GB KIT)
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (£109)
Surge Protection
Cable Tidy
I have choosen the bigger PSU for when I upgrate to a second graphics card. Do guys know if I bought a second NVIDIA graphics card if SLI would work without a problem or would it be best to buy one as followed below:
Intel® Core™i7-2700k Quad Core (3.50GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V PRO/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX
2nd Graphics Card
COOLIT ECO II C240 DUAL RADIATOR CPU COOLER (£99)
Surge Protection
Cable Tidy
I'm thinking that graphically this second one would be better, but obviously would love to hear your oppinions on it.
Thanks,
Bruno
brulei
How about this machine instead?
2nd Graphics Card
Surge Protection
Cable Tidy
Price: £2,537.00 including VAT and delivery.
Will the graphics cards work in SLI well?
brulei
What do you guys think of this one instead? Better value for money and not excessive?
2nd Graphics Card
Surge Protection
Cable Tidy
TravelSite
With 32GB you can set up a RAM CACHE to speed things up applications in use (e.g. a 8GB RAM CACHE).
In addition to this you can also set up a RAM DISK (e.g. 16GB RAM DISK) storing your most popular programs (or a game) on it to really increase the speed - though the downside to a RAM DISK is that it needs to save itself to your SSD (or wherever) on shutdown (and load on startup).
ASUS ROG forum lists software which does these two things (I have done the RAM CACHE but not the RAM DISK yet) with useful guides (and there are corresponding YouTube videos illustrating the speed difference).
I'm using the PC for database stuff with the odd bit of gaming - I have no idea what effect it would have on gaming (if any) sorry.
