Ubuntu 22.04 on Elimina 15.6 - i7 13700H & Nvidia geForce GTX 1650 (working)
Maieul
Hey there,
I couldn't find any posts regarding Ubuntu on the Elimina series, so I thought about sharing what I've been through, in case it can help you.
I just used a USB drive and followed the first guide I found online, everything was easy to set up, even without windows installed by default (pcspecialist includes a 30 days trial windows version, but I guess it's not even needed), except for the nvidia driver. I don't know why but I couldn't boot anymore with the nvidia-driver-530-open, even though it appeared as "recommended", but when I use the 525, everything's working fine.
There are also a few small errors on startup, but it doesn't seem to change much.
Cheers,
Maieul
Mnemonic
Do you know if "Runtime D3" (RTD3) is working on this model? Also, do you know if it's possible to run an external monitor with the Nvidia GPU powered down?
