Hi all, just received a new Octane 3 PC with 4Ghz intel and 1080 GTX GPU.
I've replaced the standard HD with two 512 SSD's and using an external CDROM drive switched of UFC? in the bios to enable booting from a CD with the Windows 10 CD sent with the machine and hit F7 to choose the install path.
This is where a few issues creep in.
First, despite connecting a mouse or using the track pad I can't select any of the menu choices for language. No tab or directional arrows, only enter works so had to work round this by changing US language and time settings after install. No big deal.
Secondly, installed the various drivers, intel, Wlan, audio etc: - I get the following error when I try to install the VGA driver. 'Nvidia installation is not compatible with this version of windows.' I've tried installing the international Nvidia driver and get the same message.
Thirdly, I can't go online using Microsoft Edge. When launching it say's something like Microsoft Edge can't start please change UAC settings. If I go to User Account Control settings, it is already set at the bottom, so is already switched off. If I slide it up to medium or high the screen resolution immediately jumps from native 1080p too 640? Naturally I'm now becoming a bit suspicious the UAC and Nvidia issue are related in some way and there is a compatibility problem with the tech and the windows version.
I would like to upgrade to latest windows version, but again it say's its fully up to date.
Any thoughts, this is driving me a bit mental.
