Calling all troubleshooters, AgentCooper needs some added brain cells to help him out...
Went to turn on my PC today and forgot to switch the monitor on before I did so. When I’ve done this in the past, the system powers on but no signal reaches the monitor, I have to press and hold the power switch on the tower until it forces shutdown. Then I switch the monitor on, turn on the tower again and everything returns to normal. But today... that didn’t work.
Here’s my specs...
AMD Ryzen 7 3800X Eight Core CPU (3.9GHz-4.5GHz/36MB CACHE/AM4)
Corsair H100i RGB Platinum
LED Lighting
50cm ARGB LED Strip
2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
Firefox™
Cable Management
3 x PCS 1.5M Zip Cable Tidy - Professional Cable Management
And my monitor is the AOC CU34G2X.
Things I have tried...
1) Using different DisplayPort connections.
2) Using a HDMI cable
3) Removing all USB devices
4) Reseating the GPU
5) Reseating the RAM sticks
6) Resetting the CMOS
7) Abusive language
None of which have worked, I’m sad to say. Any ideas from the hive mind?
Note - whilst I had my head in the tower, I could see this wee orange light on the motherboard.
And yes @Martinr36, that cable next to it is the one that amused you so much in the past 😝
Here’s my specs...
LED Lighting
50cm ARGB LED Strip
Firefox™
Cable Management
7) Abusive language
