TongFang GK7MRFR motherboard drivers
Alakanu
TongFang doesn't seem to have a public repo for drivers, what's the current advice on where to get them? I am only missing some, one sm bus controller and 3 pci devices. My purchase didn't include an operating system and I got the smallest ssd possible because I simply moved my ssd from the old laptop to the new without reinstalling windows.
Is this a PCSpecialist machine? Can you post your full specs from the order page ?
Alakanu
It is a pc specialist laptop. Here it is :)
Optimus Series: 17.3" Matte Full HD 120Hz 45% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 10750H (2.6GHz, 5GHz Turbo)
32GB Corsair 2400MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® GTX 1650 Ti - 4.0GB GDDR5 Video RAM - DirectX® 12.1
128GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W) ---------> Replaced with a Crucial CT1050MX300SSD1 1TB 2.5" SATA SSD
AC Adaptor
1 x 150W AC Adaptor
1 x 1 Metre Cloverleaf European Power Cable
2 x Optimus Series Battery Pack (One Spare, Requires Assembly)
OPTIMUS SERIES RGB BACKLIT UK KEYBOARD
NO RECOVERY MEDIA REQUIRED
INTEGRATED 1MP HD WEBCAM
AC Adaptor
1 x 150W AC Adaptor
All your drivers are in your main PCS account in the tech support section.
you need to do a clean install of windows as that wont be correctly configured for your new laptop
Alakanu
I used windows recovery functionality to reinstall windows keeping my files. It's still not finding the drivers for those devices.
The auto search doesn't find anything and the drivers are not among those downlodable from pcspecialist. Any clue? I was thinking to pay a visit to driverscape but I'd rather get them from the official source.
Vendor (ven) is intel (8086 - geddit?). I'm thinking those are chipset drivers. Have you done a windows update for optional drivers? Sometimes they are listed there.
You need to clean install Windows and all your programs on the new hardware. I appreciate you're trying to avoid doi g that but if you want a stable and reliable operating system then there are no shortcuts.
Alakanu
@ubuysa I've deleted all the partitions and done a clean install. Same drivers missing. By the way it was never the case that the laptop didn't work, it's just those drivers missing.
@Wessexelectricnut I think you're right for some reason I thought it was something to do with the motherboard but maybe it's the processor. I'll seek the right drivers on the intel repo.
When you did the clean install did you install ALL the optional updates, including those in the drivers section
