TN, VA, & IPS panels compared
LED is just the generic panel description...within that you've got TN, VA, IPS (each have their own pros and cons) [Tom's Hardware Linky].
TN Panel Pros and Cons
This design allows for fast response times (the time between the panel getting the frame it’s supposed to display and actually displaying it). It also allows for fast refresh rates. Consequently, TN panels are the only 240 hertz (Hz) gaming monitors available right now.
TN panels are cheap but suffer from poor viewing angles due to the “twist” only being aligned in one direction for viewing the panel straight on. They can also have poor color and contrast due to this twist mechanism not being the most precise or accurate.
VA Panel Pros and Cons
This structure produces deeper blacks and better colors than TN panels. And multiple crystal alignments (shifted a bit off axis from each other) can allow for better viewing angles compared to TN panels.
However, VA panels come with a tradeoff, as they are often more expensive than TN panels and tend to have lower refresh rates and slower response times than TN panels. Consequently, you won’t see quite as many VA panel gaming monitors.
IPS Panel Pros and Cons
IPS panels have the best viewing angles and colors of any LCD monitor type, thanks to its crystal alignment always lining up with the viewer. And while they don’t offer as fast a response time or refresh rate as TN panels, clever engineering has still gotten them to 144hz, and with nice viewing angles you’re not necessarily going wrong with an IPS gaming panel.
However, they also tend to be a bit less bright due to their design blocking off a bit more of the backlight.
The Toms Hardware bit needs to be updated, this appears to be more before OLED panels hit the market as things like VAs and IPS having lower refresh rates than TN was overcome a while ago
The Hardware Unboxed video is very good.
