Comments welcome on all aspects of the below
Uses - Home office, some light coding and gaming (but nothing too FPS demanding, I'm mainly into stuff like Rimworld, Civ VI, XCOM)
Budget - Max £1000
Monitors - 2 x 24" 60Hz, usually used at 1920x1080
Thoughts - Not 100% fixed on any of the below. No reason especially that I am going with AMD over Intel other than that I have always used AMD before and historically they have a reputation of being slightly better value. 32GB RAM seems like overkill, but it seems very cheap at the moment at only £36 to go from 16GB to 32GB, so maybe it's worth it to save an upgrade later? I have spent a bit of time with the graphics cards on userbenchmark.com and the RTX 4060 seems to be thought of as the best value card in that price range. It is a significant upgrade over the RX 580 I currently use (which has always been able to run everything I wanted it to but obviously also looking to the future). I haven't included a second HD as I already have a 4TB SATA drive that I can add to store all my music, photos and other stuff like that if needed. Motherboard, PSU and Processor I am the most clueless about so if any of these are unsuitable or there is an obviously better choice within budget then let me know
Thanks in advance!.
PCS PRISM-X ARGB MID TOWER CASE
AMD Ryzen 5 5500 Six Core CPU (3.6GHz-4.2GHz/19MB CACHE/AM4)
GIGABYTE A520M K V2: Micro-ATX, AM4, USB 3.2, 6GB/s
8GB NVIDIA GEFORCE RTX 4060 - HDMI, DP, LHR
2TB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
STANDARD AMD CPU COOLER
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Microsoft® Edge
Standard Build - Approximately 9 to 12 working days
Price: £918.00 including VAT and Delivery
Budget - Max £1000
Thanks in advance!.
Microsoft® Edge
