Thoughts?
Hudderz
COOLERMASTER MASTERCASE H500M GAMING CASE
Overclocked CPU
Overclocked Intel® Core™ i9-10900K 10 Core (3.7GHz @ up to 5.1GHz)
ASUS® TUF Z490-PLUS GAMING (LGA1200, USB 3.2, CrossFireX) - ARGB Ready
10GB ASUS ROG STRIX GEFORCE RTX 3080 - HDMI, DP
1x 120mm Thermaltake TOUGHFAN 12 Case Fan
Capture/Streaming Cards
Elgato Game Capture 4K60 PRO MK.2 - PCIe Card
Monitor Cables
2 x 2m DisplayPort Cable - DP (M) to DP (M)
Surge Protection
6 Socket 2m Surge Protector
Standard Build - Approximately 17 to 19 working days
Promotional Item
Get CoD:Cold War & 1YR GeForce Now w/ select RTX Graphics Cards
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z490-overclocked/qWEKDRgYHU/
Bigfoot
Grand Master
Is this for gaming or for other applications? What monitor will you be using (make and model or resolution and frame rate)? What is your maximum budget?
In almost all applications you will be better off with AMD than with Intel at the moment.
Bigfoot
Grand Master
Check out this post
You’d be throwing money away by going for both an Intel build at the moment. And also by pairing a 3080 with a 1440p monitor. The 3070 would be more than enough. Here’s a sexy AMD alternative spec...
CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
Firefox™
Price: £2,679.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/AN3dTnRxJJ/
Hudderz
Firefox™
Thanks for the suggestion made some change though want to get a 3080 with it as a new monitor isn't that far away. just want to make sure I dint mess up the build.
Surge Protection
Promotional Item
Bigfoot
Grand Master
You don’t need the Arctic MX-4 thermal paste with that cooler, as it has high quality paste pre-applied.
MrWilson
Surge Protection
Promotional Item
If you’re getting a new monitor to utilise the power of the 3080 then it’s definitely worth buying.
Recent purchases have had issues with 4x8GB 3600mhz RAM configurations only able to have the RAM perform at 3200mhz. I would recommend sticking to 4x8GB 3200mhz until this gets sorted out.
For your boot drive, I would recommend the Samsung 980 pro, it’s blisteringly fast for loading windows and your programs.
