Thought's & Opinions Welcome
MrShteeeve
Hello all :),
It's been a while since I've been here but I'm back and with a little task for whoever has a spare 10mins...
I've got ideas for my desktop already and I'm relatively A-OK with building specs (as some of the older posters may know)
But I just want a little input from you guys :).
The criteria is this:
  • £2000 budget (or as close to as possible)
  • SSD as primary
  • Non standard keyboard & mouse
  • 2 monitors
  • Decent cooler & case
  • Additional speakers
  • Wireless Card
As long as it contains these and can handle most games out @ steady FPS and maybe some CAD it's fine.
Thanks in advance all, I look forward to your propositions,
Steve
vanthus
Member Resting in Peace
I selected an 850w PSU to allow for adding a second GPU in future,so you can drop that down if you have no intentions of doing so.
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
120GB INTEL® 330 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD (£16)
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£129)
2nd Monitor
LOGITECH® G110 GAMING KEYBOARD WITH BACKLIGHTING (£69)
Mouse
LOGITECH® G500 LASER GAMING MOUSE (£48)
Speakers
LOGITECH S220 2.1 SILVER/BLACK SPEAKER SYSTEM (£19)
£1919 inc VAT and Delivery.
bigben
Master Poster
Hi there, I don't claim to be any sort of expert but based on things I have picked up from the forums this would be good. I put monitors on the quote but didn't add keyboard or mouse as that is just preference, I also didn't add speakers however you have plenty of room in your budget for adding these.
I believe the GPU will run just about everything on high settings at the moment.
The SSD is only 120GB because anything more gets expensive.
Finally, have you considered homeplugs instead of wireless. I have these for my xbox and it sends the signal perfectly to the other end of the house, it is much better than the wireless.
I looked at the requirements for CAD and this should run it easily.
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE preference, I think most of the cases would be ok
Intel® Core™i5 Quad Core Processor i5-3550 (3.3GHz) 6MB Cache
ASUS® P8Z77-V PRO: PCI-E 3.0 READY,WIFI, SLI, CROSSFIREX
2GB NVIDIA GEFORCE GTX 670 - 2 DVI, HDMI, DP - 3D Vision Ready a lot cheaper than the 680 and not much difference
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69) go for higher if you decide to sli gpu
Monitor
IIYAMA E2473HDS 24" LED WIDESCREEN, 2 HDMI/DVI-D 1920x1080 (£159) don't know what size monitors you wanted
2nd Monitor
Price: £1,562.00 including VAT and delivery.
£2000 seems a lot for just gaming and cad...
