Thoughts on this spec please? Potent, but also capable of running reasonably quietly
cliwil
Looking for fairly potent laptop for development/unity/vr hobbyist, but I still want it to be fairly quiet when not being pressed hard. How do you think something like this would fit?
Defiance Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
32GB Corsair 2133MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2070 Max-Q - 8.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 180W AC Adaptor
Defiance Series Integrated 3 Cell Lithium Ion Battery (73WH)
1 x THUNDERBOLT 3 PORT + 3 x USB 3.2 PORTS
17" DEFIANCE SERIES UK KEYBOARD
Windows 10 Professional 64 Bit - inc. Single Licence
INTEGRATED 1MP HD WEBCAM
Home Installation
NONE
Dead Pixel Guarantee
30 Day Dead Pixel Guarantee Inc. Labour & Carriage Costs
Chassis
Clevo PC70DF1 (8GB RTX-2070 Max-Q, i7-10875H, 144Hz N7, Blank KB)
Price: £1,867.00 including VAT and Delivery
Thanks all :)
Grumpywurzel
Can you add the url so that peeps can go in and tweak pls? Whats the budget?
Is there a reason why you need 32GB of RAM? I'd be tempted if you can afford it to try and spend the cash on the higher speed, most applications only need 16GB
In desktop machines the consensus would be to go AMD over Intel. I dont know what the AMD laptop options are tbh, but it might be worth you exploring those unless you specifically need Thunderbolt 3? You'll get a better bang for buck
cliwil
Yes, here you go
https://www.pcspecialist.co.uk/saved-configurations/defianceVII-17/cNXfVEtZQW/
Budget £2000. Highly spec'ed RAM because it's likely to be used to write computationally complex 3D applications; experiments with own game/3D engine, that sort of thing. I'd normally spec 16GB but had a bit of budget left, so spent on that :) I'm not sure a faster processor would do much, but a faster GPU might. It would be used for day-to-day stuff too though, so ideally it shouldn't sound like a helicopter when it's not being pushed flat out. The 2nd 1TB drive isn't essential; could use that budget elsewhere if need be. Not particularly bothered by thunderbolt.
I'm not that familiar with AMD processors; I usually go for Intel i7+ and haven't looked at the AMD range. Which AMD's are broadly comparable/faster? Is compatibility 100%?
