This spec ok for work and games?
anav.
Hello guys, thanks for the support. I am looking to buy a new computer to work mostly with after effects and maya, and also for gaming, online games and dragonage/assassin's creed solo type of games. My budget is about 900 pounds. I made this spec but i am not sure if i chose the right thing, very far from being an expert here :)
Thanks again in advance for your help.
COOLERMASTER ELITE 311 BLUE CASE
Intel® Core™i7 Quad Core Processor i7-3770 (3.4GHz) 8MB Cache
ASUS® P8Z77-V PRO/THUNDERBOLT: PCI-E 3.0 READY,WIFI, SLI, X-FIRE
1GB AMD RADEON™ HD7770 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 3 Capable
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
FREE 60 Day Trial of Microsoft® Office® 2010 Professional Edition
I'd suggest upgrading the graphics card and getting the non-pro version of the motherboard you selected (P8Z77-V LX), the spec below has a better graphics card but a cheaper motherboard and only 500gb caviar black.
CORSAIR CARBIDE SERIES™ 200R COMPACT GAMING CASE
ASUS® P8H77-M: M-ATX, DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX™
16GB SAMSUNG DUAL-DDR3 1333MHz (4 X 4GB)
2GB NVIDIA GEFORCE GTX 660 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
Free Item
FREE BORDERLANDS 2 GAME with NVIDIA GTX 660Ti/GTX 670/GTX 680!
500GB WD CAVIAR BLACK WD5003AZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Genuine Windows 8 Standard Edition 64 Bit - inc DVD & Licence (£79)
Price: £895.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-home-office-pc/ojdVcxgDHQ/
Karnor00
Keynes spec is very good I think - it has a much better GPU (important for gaming).
However you should be aware that it doesn't support SLI (although you would need a larger PSU for this in any case) and also doesn't have WIFI so you would need a WIFI card if this is required.
