The wait begins
Ordered this spec for hd editing using adobe. What do you think? I was a bit unsure on which gaphics card to use but in the end picked the one below. Never built my own pc before so pretty excited :)
COOLERMASTER HAF 922 MID TOWER GAMING CASE
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8P67 PRO (NEW REV 3.0): USB 3.0/SATA 6Gb/s, CrossFireX™ & SLI
2GB NVIDIA GEFORCE GTX560 Ti - 2 DVI,HDMI,VGA - DX® 11, 3D Vision Ready
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£89)
2nd DVD/BLU-RAY Drive
CORSAIR 850W TX SERIES (TX850) 80+ ULTRA QUIET PSU (£99)
COOLIT ECO C240 A.L.C (ADVANCED LIQUID COOLER) (£99)
Sound Blaster® X-Fi™ Xtreme Gamer (£59)
ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI-E CARD (£19)
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 12 NOON) (£19)
Price: £1,489.00 including VAT and delivery.
Ordered on a sat so that's two days without nothing been done! :( I know these guys need a weekend off but to us waiters it can't come quick enough! Thanks in advance for all those who will be involved with this build :)
Thanks for info, don't know much about over clocking but thought I might try it some time if I need it, is this spec OK for this or do I need that CPU paste, what is it and how does it work? I already have the CoolIT Eco, and I think the wattage is high enough.
Nemesis
All your spec is well set for overclocking. You should be able to get a pretty high clock with those specs.
I would buy some thermal paste and apply it before overclocking (Youll be fine without until then)
If your order is still in pre production the amendents are free btw :)
and if comments are welcome id change the HDD setup to a 1TB caviar black as your primary drive and a 2TB caviar green as your secondary storage drive
Its always best to have your OS on a smaller HDD as if it goes wrong it takes all then info on the partition/drive with it.
Thanks for that. I will have to phone them tomorrow about it, I think the thermal paste would be good but didn't see it in the build list, not sure on what it cost? How do I add +rep? can't see a link to add it to your profile. Appreciate the feedback thanks
Nemesis
its the star to teh left of the triangle underneath my profile pic :)
and your welcome
Normally the thermal paste is only offered on the overclocked pc configurator but if you call up/ email them then im sure theyd be happy to build your pc with thermal paste included
*thermal paste will be applied in the building as default but you will want better quality paste for overclocking
