The Ultimate Desktop PC £1900 Budget - Advice
Hello everyone hope you're all doing well. So for the past few months I've been saving-up for the Ultimate Desktop PC. I really hope someone can help me out as I really need some recommendations/advice.
At the moment I have 2 x 24.7" Philips HD Monitors connected to my current Desktop PC and the Spec is quite crap, standard 8GB RAM but it's been doing fine for almost 5 years, now it's time for an upgrade: The Ultimate Upgrade
The Ultimate Desktop PC will be mainly used for video editing. I'll be using Sony Vegas as the main editing software.
If you could take the following into consideration I would really appreciate:-
Budget:- £1200 - £1900
Please don't include the monitors into the budget. Only the desktop PC.
Also I maybe able to add some extra funds.
Many thanks
Steve
The Ultimate Desktop PC - Advice
- Case - Control fan speed
- Monitors - Atleast 4 monitors HD
- Eye Infinity?
- Storage - Large storage required
- USB Ports - As many possible
Many thanks
Steve
