Defiance Series: 15.6" Matte Full HD 120Hz IPS LED Widescreen (1920x1080)
Intel® Core™ i7 Quad Core Processor 7700HQ (2.8GHz, 3.8GHz Turbo)
32GB Corsair VENGEANCE 2400MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1
1st Hard Disk
1TB SEAGATE FIRECUDA 2.5" SSHD - UP TO 5X FASTER THAN HDD!
M.2 SSD Drive
256GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1100MB/W)
AC Adaptor
1 x 150W AC Adaptor
1 x 1 Metre Cloverleaf European Power Cable
Intel 2 Channel High Def. Audio + MIC/Headphone + SoundBlaster X-Fi MB3
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0
3 x USB 3.1 Type A, 2 x USB 3.1 Type C AS STANDARD
RGB BACKLIT USA KEYBOARD
US International/USA - US English Language
DVD Recovery Media
NO DVD RECOVERY MEDIA REQUIRED
Laptop Cooling Stands
CoolerMaster MasterNotePal Laptop Cooler, upto 17.3 inch
Notebook Mouse
Dead Pixel Guarantee
Unity has no future tho... It never had it.
I bet most people wouldn't even notice the difference...
Hi, I did...
Bought the Defiance XS recently...
Just wondered if anyone has upgraded to Ubuntu 17.10, Artful Aardvark, and what they think about it. It was great for my Optimus VII as it worked out of the box but I am sorry to see them ditch Unity as that was one of the reasons I went with Ubuntu originally.
Hey Manioa - I currently have the Defiance II and love it so much I'm thinking about getting the Defiance XS within the next month. I have a couple of questions:
Does the 120Hz screen work at 120Hz (using the proprietary Nvidia driver)? Or does it drop to 60Hz?
Are you able to cut power to the Nvidia GPU and use the Intel GPU?
What kind of battery life are you getting?
On my Defiance II, I have a setting in the BIOS to switch between "DISCRETE" and "MSHYBRID" GPU. Is there something similar on the Defiance XS?
Any info would be much appreciated.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=\"!Windows 2015\""
sudo update-grub
Nothing worked. Anyway , the most annoying thing is I have no sound , except for my HDMI monitor.<allow send_destination="org.freedesktop.UPower"
send_interface="org.freedesktop.UPower.KbdBacklight"/>
*-multimedia
description: Audio device
product: Sunrise Point-H HD Audio
vendor: Intel Corporation
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 31
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=snd_hda_intel latency=32
resources: irq:130 memory:df320000-df323fff memory:df300000-df30ffff
$ sudo prime-select intel
$sudo prime-select nvidia
options nvidia_384_drm modeset=1
sudo update-initramfs -u
