The PCS Maelstorm Case
Seedsy
Hi folks,
seen on another thread that someone's case came without side fan as the cpu cooler didnt fit with it. wondered if with this would be the case with mine.
Inwin Fanqua (The PCS Maelstorm Case)
Intel® Core™i5-2400 Quad Core (3.10GHz, 6MB Cache) + HD Graphics
ASUS® P8H67-M LX SI (NEW REV 3.0): M-ATX, USB 2.0, SATA 6.0Gb/s, 2 x PCI
1GB NVIDIA GEFORCE GT 430 - DVI,HDMI,VGA - DX® 11
Hard Disk
Hard Disk Partitions
80GB, 800GB, 120GB
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER
ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD
Seedsy
Teaz
I dont think so, it should fit as the tripple copper isnt too large. Best way to double check is to phone up the pcs team and they will let you know :)
