"testing" phase question
mukdore
Hi, just looking at my order and its in the "in testing" phase , just wondering if anyone knows what kinds of tests they run? because im a bit worried about how the computer will run under high strain and things like that .
thanks for any replys
mantadog
Superhero Level Poster
I don't know the exact tests they do but it will be something along the lines of running the components at 100% for something like 24 hours. They then check the reports for any errors and take action as appropriate.
I also believe it is done inside a room which has a much higher temperature than you would expect to find in a house to make sure that the cooling is adequate.
So right now if your PC is in testing mode it will be running something like prime95 to test the CPU and cooling, they will then run tests on the RAM, GPU and HDD to make sure everything is functioning correctly and probably other tests for USBports etc but I don't know 100% on that.
So don't worry too much, they are probably abusing right now more than you will when you get it so if it survives the night your good to go :p
