System Performance Error
Linda
Only had this system since mid September and have slowly been adding software etc.
So today I thought I would do the system performance.
As you can see I have the error could not measure system memory performance.
I have not phoned pcs yet as it is getting towards closing time so thought I would ask here if anyone can give me some advice and guidance.
Linda
Hi Oussebon
You will never believe this but I did a Google on my problem and like you came across this article I am scenario 1.
I see there is a download fix but it is quite an old one if I recall back 2011.
So not sure if it is still relevant.
Also my Processor (CPU)Intel i7 eight core 20mb cache
If you're still using Windows 7 and still getting the error message on a CPU with a greater than 16MB cache I assume it's still relevant.
Linda
Yes still using Windows 7 in the build I had done.
What I have done is applied for the hotfix as you have to request it.
I will now have to check my emails.
When I get it I will then before installing it phone pcs in the morning and check if ok to use it as I do not want to do anything to invalidate my warranty.
Rakk
The Awesome
Though to be honest the Windows Experience Index is actually a pretty worthless scoring system, it scores it on the worst bit of your PC which is not always a relevant bit - there are plenty of other performance testing tools out there, personally I use 3D Mark, and I'm sure other forum users can suggest many others (I can't think of any at the moment but that's probably cos I'm waiting for dinner to finish cooking and am starving :))
Linda
Thanks Rakk and Oussebon for alternatives.
I received the link but after reading this (pasted below) that was part of the email I think I will not bother even downloading it as you will see it has not been fully tested.
WARNING This hotfix has not undergone full testing. Therefore, it is intended only for systems or computers that are experiencing the exact problem that is described in the one or more Microsoft Knowledge Base articles that are listed in "KB Article Numbers" field in the table at the end of this e-mail message. If you are not sure whether any special compatibility or installation issues are associated with this hotfix, we encourage you to wait for the next service pack release. The service pack will include a fully tested version of this fix. We understand that it can be difficult to determine whether any compatibility or installation issues are associated with a hotfix. If you want confirmation that this hotfix addresses your specific problem, or if you want to confirm whether any special compatibility or installation issues are associated with this hotfix, support professionals in Customer Support Services can help you with that. For information about how to contact support, copy the following link and then paste it into your Web browser:
I think that's very wise. As Rakk and Oussebon have said, the Windows Experience Index isn't that useful and it's certainly not important. Sometimes it's enough to know that a problem doesn't require fixing and you're so right to point out that it's quite possible for the 'fix' to be more dangerous than the original problem.
