System for moderate gaming sub £1000 - Is this a good spec ?
Pooler
Dear All
I want to get back into PC games after a long absence. I'll be an occasional gamer, not an enthusiast but still I would like to be able to play the latest games at a good graphics level and speed.
My key things I want are
Silence (Hence the expensive case)
Quick Start Up (Hence the SSD)
Large second drive capacity
I've deliberately gone for a CPU without on board graphics as have added a proper graphics card (I assume this saves a few quid and is the right thing to do)
Any comments from experts would be much appreciated, here is my spec :)
FRACTAL DEFINE R5 BLACK QUIET MID-TOWER CASE
AMD Athlon X4 880K Quad Core CPU (4.0GHz/FM2+)
ASUS® A68HM PLUS FM2+ (M-ATX, DDR3, USB 3.0, 6Gb/s)
8GB HyperX FURY DUAL-DDR3 1600MHz (1 x 8GB)
8GB AMD RADEON™ RX 480 - HDMI, 3 x DP - DX® 12
1st Hard Disk
240GB BiWIN 2.5" SSD, SATA 6 Gb/s (upto 559MB/sR | 514MB/sW)
5TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 128MB CACHE
Super Quiet Titan DragonFly Heatpipe AMD CPU Cooler
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
DVD Recovery Media
This CPU is very weak. To give you some idea, here it is compared to an Intel i5: http://www.anandtech.com/bench/product/1707?vs=1646
You're absolutely right that CPUs with above average onboard graphics such as AMD's APUs are best avoided when pairing with a decent dedicated GPU, because obviously if part of the cost of what you spend is going on something you won't be using, that's a waste of money. However, many CPUs these days have some level of onboard graphics as standard. The best gaming CPUs are Intel ones - despite the fact they have Intel HD graphics.
If you want that much storage you should probably be giving some though to a NAS / Network Attached Storage.
Leaving that to one side, here's an alternative spec:
Intel® Core™i5 Quad Core Processor i5-6600 (3.3GHz) 6MB Cache
ASUS® H110M-R: Micro-ATX, DDR4, LG1151, USB 3.0, SATA 6GBs
16GB HyperX FURY DDR4 2133MHz (2 x 8GB)
1[SUP]st[/SUP] Hard Disk
2[SUP]nd[/SUP] Hard Disk
1[SUP]st[/SUP] DVD/BLU-RAY Drive
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler (£19)
Genuine Windows 10 Home 64 Bit - inc DVD & Licence (£89)
Price: £990.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-skylake-home-office-pc/YpBYk74Hvk/
Pooler
Many thanks Oussebon - that's exactly the sort of help I needed. I shall certainly go for the Intel Processor as you suggest.
I shall look into a NAS drive. I already have a MyBook 2TB drive which gives me ample Network Storage for stuff I want to share around the home - I was under the impression though that if your data does not need to be shared around a network then an internal hard drive would always be the fastest option and cheapest option ? I'm going to be using it to store Hi-Def movies (4k) and my experience with the MyBook leads me to believe that speed / transfer rates don't compare to internal ?
