Hi there.
I have an ASUS ROG Strix B550-F Gaming motherboard and a Corsair iCUE H150i Elite RGB CPU cooler, and I want to connect the CPU fans to my motherboard in order to control them via Fan Control as they are currently controlled by the CPU commander. However, I'm a bit stumped on how to do this correctly.
I've tried looking for tutorials on how to properly swap the two but most of what I can find are tutorials for people who are in the process of building their PC and are connecting their fans to either or.
I know I have to connect my CPU fans to the CPU_FAN header on my motherboard but I dunno if it's just a case of simply swapping some cables or if I have to use an additional cable. I have a 3-pin TKG 2510 cable in my Welcome Pack with 2 black 2-pin and 1 white 3-pin connectors attached but I'm not sure if this is the correct cable.
As for the commander, do I just leave it in there or should I remove it? Sorry for the daft questions, just looking for a step-by-step guide on how to do it before I attempt it. I don't want to end up with both connected simultaneously or some strange wiring going on.
Thanks.
Thanks.
