Hi, here I sit with my new delivery from PCS (spec posted below). The spec was very helpfully evolved on this forum, and included a fast, bigger SSD for boot, and a smaller, slower one for a video edit scratch drive. No HDD (I have one already), and no OS (I have a license to transfer as its precedessor PC failed). I was aware that PCS leave a trial, unlicensed, W10 on-board after testing, which suited me perfectly as it saves me work and a big download on my sHaKeY mobile internet.
Well, it arrived, and it works, but for some reason PCS have set up the second (and it is second!) slower SSD as the boot disk, leaving the nice fast one blank. Doh!
Q1: To what extent will the commissioning W10 be "nicely" set up for the specific configuration, as against W10 simply sorting itself automatically? In other words, will what's on the slower SSD be better than I'll get with a fresh install (me being a bit of a duffer)?
Q2: Is there a sensible process I can follow to swap over the Windows installation (and C: status) from the slower SSD to the good one?
I won't have any immediate need to use the slower SSD afterwards, I could leave it out for some while, or (can I?) disable it in BIOS.
Hoping for help.
Cheers, Gideon
Spec
6GB ASUS DUAL GEFORCE RTX 2060 - HDMI, DP, DVI
256GB PCS PCIe M.2 SSD (1900 MB/R, 1100 MB/W)
Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
NO RECOVERY MEDIA REQUIRED
Standard Build - Approximately 14 to 17 working days
Welcome Book
Logo Branding
PCSpecialist Logo
Hoping for help.
Cheers, Gideon
Spec
Welcome Book
Logo Branding
PCSpecialist Logo
