Suggestions for a tower stand? Fractal Torrent
Gage
Hi, I've ordered a new build with the Fractal Torrent Case. It's going to need to go on th floor so I've been looking at case stands, the type that are just a base on wheels, with cut-outs for air flow, but none of them are quite long enough, and because of the way the feet are on the case I'm concerned it won't sit properly on them, even if the stand is just a couple of cm short either end.
Does anyone have any good suggestions for a suitable case stand for this case, that won't inhibit the airflow at the base too much?
Thanks!:)
Thanks!:)
It's not like the old days, cases have feet these days to lift them off and not impede airflow.
Unless you're putting it on a very thick pile carpet, you won't need a stand.
Gage
Thanks. It would be sitting on carpet, which I was a bit concerned about, and thought it would be better to be a few inches off the floor because of dust etc.
It will be a off the floor, that's what the feet are for.
Things have changed a lot with PC design, cases are hugely better than they used to be.
