Hello all,
Just a return of experience to help anyone wanting to install Ubuntu on an Optimus IX. I used Ubuntu 18.04 Bionic Beaver because it used a kernel version compatible with Intel AC-9260 Wifi chipset; I guess this is kernel version 4.13+.
First my configuration :
Optimus IX (Clevo N850EK1)
Then, I should precise that I disabled Secureboot on BIOS/UEFI settings. I guess this should have no consequence if this has been omitted because Ubuntu should handle SecureBoot.
OK, this is how I did :
I hope this will help someone.
Finally, thanks
Kind regards
EDIT 1: Forgot mention about SecureBoot
EDIT 2: Forgot Backlit keyboard driver source modification before build
- Matte LED display 15,6" 144 Hz 72 % NTSC Full HD (1920 x 1080)
- Six Core Intel® Core® i7 8750H (2,2 GHz, 4,1 GHz Turbo)
- 32 Go Corsair 2400 MHz SODIMM DDR4 (2 x 16 Go)
- GeForce® GTX 1050 Ti - 4 Go de RAM video GDDR5
- SSD M.2 256 Go WD Black™ NVMe PCIe M.2 SSD
- Integrated memory card reader 6-in-1 (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
- 2 Channel High Def. Audio + SoundBlaster™ Cinema 5
- GIGABIT LAN and WI-FI INTEL® AC-9260 M.2 (1.73 Gbps, 802.11AC) + BT 5.0
- Options USB 1 PORT USB 3.0 (Type C) + 2 PORTS USB 3.0 + 1 PORT USB 2.0
- Backlit RBG Belgian Keyboard
- Integrated Webcam 1MP HD
- Make a bootable USB key with Ubuntu 18.04
- Boot on this USB key
- Start the installation interface without issues
- Select "Install Ubuntu" on GRUB menu and type on "E" key. Then the menu configuration is shown.
- Locate the line beginning with linux and insert "acpi=off" before "---". For example :
Code:linux /casper/vmlinuz file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash acpi=off ---
- Once done, key CTRL+X so that the system should boot until the installation interface
- Basically install Ubuntu (I do not detail because it depends of the laptop options)
- Choose all your settings
- Do not forget to check the box before "Install third-party sofware for graphics and Wi-Fi hardware and additional media formats". Thereby Intel Wifi, bluetooth and NVIDIA graphics card drivers will be installed by default
- Make your partition plan
- Proceed installation
- Once done...
- Restart the computer to boot on newly installed Ubuntu system (do not forget to remove the USB key)
- Select "Ubuntu" and key upon "E"
- Add "acpi=off" at the end of the line starting with "linux"; otherwise the computer might freeze. In my case this looked like
Code:linux /boot/vmlinuz-4.15.0-23-generic root=UUID=f8888889-8888-8888-8888-888888888888 ro quiet splash $vt_handoff acpi=off
- Key CTRL+X to boot
- Connect with the user defined during installation
Here you may see two disturbing things:
- There is only on CPU. That's OK for the rest of the install process
- The keyboard might seem not responding. Indeed, restarting twice the application give the keyboard's echoes back
- Install NVIDIA-PRIME
- Start a terminal
- Type
Code:
sudo apt install nvidia-prime mesa-utils nvidia-driver-390
the nvidia-driver-390 is the last I saw nowadays, it may evolve in the future - Restart the computer
Here, do no more add "acpi=off" at the end of the linux line. Remark there are 12 CPU and the keyboard functions directly
- Check that NVIDIA Prime is operational
- Start NVIDIA X Server Settings
I search it from the menu "Activities" - Check if PRIME Profiles is present
- Select it and confirm that you have both NVIDIA and Intel profile
- Install keyboard backlit driver
- Start a terminal
- Install git software
Code:
sudo apt install git
- Install build tools
Code:
sudo apt install build-essential
- Make sure the home directory is the current one
Code:
cd
- Install the source of the driver
Code:
git clone https://bitbucket.org/tuxedocomputers/clevo-xsm-wmi
- Go to the source driver directory
Code:
cd clevo-xsm-wmi/module
- Modify the file clevo-xsm-wmi.c
- find the __initdata
- and insert the bold lines as this
Code:static struct dmi_system_id clevo_xsm_dmi_table[] __initdata = { [B] { .ident = "Clevo N8xEJEK", .matches = { DMI_MATCH(DMI_PRODUCT_NAME, "N8xEJEK"), }, .callback = clevo_xsm_dmi_matched, .driver_data = &kb_full_color_with_extra_ops, }, [/B] { .ident = "Clevo P870DM", .matches = { DMI_MATCH(DMI_PRODUCT_NAME, "P870DM"), }, .callback = clevo_xsm_dmi_matched, .driver_data = &kb_full_color_with_extra_ops, },
The value N8xEJEK used can be found as this:
Code:sudo dmidecode | grep -A10 'PC Specialist LTD' | grep 'Product Name:'
- Build it
Code:
make
- Install it on the right place
Code:
sudo mkdir /lib/modules/`uname -r`/extra/ sudo cp clevo-xsm-wmi.ko /lib/modules/`uname -r`/extra/
- Refresh the system to take the new driver module into account
Code:
sudo depmod
- Inform the system to load the module on boot
Code:
sudo echo clevo-xsm-wmi > /etc/modules-load.d/clevo.conf
- Configure the keyboard backlit to be deactivated
Code:
sudo echo options clevo_xsm_wmi kb_sate=0 > /etc/modprobe.d/clevo.conf
Here this configuration deactivate the keyboard backlit. You can use the following parameters :
- kb_state: the state
- 0 backlit off
- 1 backlit on
- kb_brightness : its value is from 1 to 10
- kb_color: is a list of 3 colors separated by comma (either red, green, blue, magenta, cyan, yellow, white or black). For example:
Code:
kb_color=blue,yellow,red
- kb_mode: set the keyboard mode 0 to 7
- 0 (random_color): change color randomly continuously and smoothly (Christmas tree)
- 1 (custom): user selected color (default)
- 2 (breathe): color is slowly glowing
- 3 (cycle): cycle smoothly to each standard color
- 4 (wave): the color change and the backlit make a sort of wave
- 5 (dance): Yeah! Disco!
- 6 (tempo): flashing slowly multicolor mode
- 7 (flash): flashing rapidly multicolor mode
Code:echo 1 > /sys/devices/platform/clevo_xsm_wmi/kb_state && echo blue yellow red > /sys/devices/platform/clevo_xsm_wmi/kb_color
Finally, thanks
- to the french Ubuntu community for the tutorial about NVIDIA PRIME (https://doc.ubuntu-fr.org/prime)
- to user foobar to give the solution about backlit keyboard features here on this forum (https://fr.pcspecialist.be/forums/s...r-Linux-(Optimus-IX)&highlight=backlit+linux))
- to TuxedoComputers to develop a functional module for the backlit keyboard (https://bitbucket.org/tuxedocomputers/)
- to all folks around the web to have given particular information/help about issues I encountered during my attempts
Kind regards
