stupid question about water cooling
jamescrosbie340
I've just bought a new water cooled pc and wanted to know if I needed to fill the cooling system with water myself or if it will have been done for me? Here is the cooler CoolerMaster MasterLiquid Lite 240 High Performance Liquid Cooler. Thanks
TomBerry
No question is a stupid question :) PCS will fill it for you - then every year or two you would need to send it back for them to clean the loops for you and give it a re-fill
JUNI0R
The CoolerMaster MasterLiquid Lite 240 makes me think it might be an AIO ;) In which case, it's manufactured as a closed loop then sent to PCS with the liquid and requires no more maintainence than a dust of the fans and rad every few months like you would with a tower cooler anyway.
NoddyPirate
Bingo!
TomBerry
G'ah! 🤦‍♂️ Only just woke up...I shouldn't come on the forums within the first hour 🤣
Citrus_9
Expert
Liquid evaporates in time. Just wondering, is it possible to make it refill by itself from the toilet tank if a PC is in a bathroom?
