student working + gaming pc - check these specs!
I am a student, looking to build a PC suitable for work-from-home and gaming. I usually use my PC for between 6-8 hours a day, obviously for the majority of the time that's work... mostly word and number processing NOT video/photo editing or rendering. However I want the computer to also be useable for current-release PC gaming. Right now I have a second-hand gaming computer with monitor so I will be re-using that monitor, unsure of its specs but it is AOC branded. These are the specs of the computer I have been looking at (I am unsure of the suitablity of the motherboard and wireless network card, which I do not really know anything about):
PCS P209 ARGB MID TOWER CASE
Intel® Core™ i7 Eight Core Processor i7-10700F (2.9GHz) 16MB Cache
ASUS® PRIME B560-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
16GB Corsair VENGEANCE DDR4 2400MHz (1 x 16GB)
12GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
PCS FrostFlow 80 V2 Series High Performance CPU Cooler
Firefox™
Price: £1,228.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z590-pc/pQ8cQ7HxNv/
Top budget is £1250. I have created this computer in comparison to a ready-built "HP ENVY TE01-1000na Desktop PC, Intel Core i7 Processor, 8GB RAM, 2TB HDD + 256GB SSD" with a GeForce GTX 1660 Super graphics card. Total cost of that computer is £1,149 if I went for that instead.
Thanks for any help!
sck451
Here's how I'd tweak it. The 2060 is oldish now and the 3060 would be ideal, but for the budget let's stick with this. Better CPU, faster RAM, better power supply, better storage, better motherboard, better cooling, and only just over your budget.
Intel® Core™ i5 Six Core Processor i5-11400F (2.6GHz) 12MB Cache
ASUS® TUF GAMING B560-PLUS WIFI: ATX, LGA1200, USB 3.2, SATA 6GBs - RGB Ready
6GB ASUS DUAL GEFORCE RTX 2060 - HDMI, DP, DVI
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
PCS FrostFlow 100 RGB V3 Series High Performance CPU Cooler
Firefox™
Standard Build - Approximately 8 to 11 working days
Price: £1,269.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z590-pc/U6gD!H2QZR/
JUNI0R
Just thought I'd throw in here that the AMD Radeon RX6600 is currently less than both the 2060 (Dual and 12GB) models. Yes you lose some of the NVIDIA features, but the 6600 is pretty much knocking on the door of the 3060 performance wise so I'd reckon would quite happily outperform both cards anyway.
Another point worth making is, if you're not in a particular rush for this build, I'd recommend waiting until PCS adds the B660 boards to the 12th gen configurator. This will bring a 12th gen system within your budget which will give better performance than a 11400F and a way better platform for future upgrades.
Intel® Core™ i5 Six Core Processor i5-12400F (2.5GHz) 18MB Cache
GIGABYTE Z690 UD DDR4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready You could arguably go with a build with this board in it, but it's rather overspecced for the CPU you have so wouldn't make much sense. Dropping to a B660 board once they appear should bring this build nicely into budget
8GB AMD RADEON™ RX 6600 - HDMI, DP - DX® 12
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW) If you're able to spend a bit more cash, the only other upgrade I'd recommend is swapping this to a 1TB to give you proper space for games
Microsoft® Edge
Price: £1,294.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/0Xk0rUQpW9/
Thank you so much Junior! Unfortunately I do need a new PC asap as mine is on last legs.
I notice you both selected the ultra quiet power supply over the normal one, is that really worth the investment?
JUNI0R
"Ultra quiet" is just marketing talk, although it will be quieter. The bit you really want to look at is the CV and TXm. The CV is an entry level 80+ Bronze unit, it'll do the job fine but not a unit I'd actively recommend for someone. The TXm is a higher quality unit that'll be built from better parts, run quieter and more efficently with the higher wattage option we've chosen. This is kind of shown in the manufacturer warranties that Corsair themselves give both units, for the CV, it's 3 years, for the TXm, it's 7.
The other thing is wattage, the 450W will run that system, but it'll be worked pretty hard it's whole life and doesn't leave any space for future upgrades. Being a non-modular PSU, replacing the unit would also be a pain. Compared to 750W which will run much more efficently under less stress and will allow for the option to pop in a new GPU when desired a few years down the line.
I like to think of is that it's similar to a car engine, with the revs being the wattage used and the redline being the maximum wattage. If your revs are always close to the redline, it's bad for the engine and will shorten the life expectency of the engine, or worse, could break it. Where as if revs are low and redline is high then it's much happier. It's the same with the wattage of PSU's really.
The PSU is actually one of the 3 parts to my holy trinity of foundations for a PC (along with case and motherboard) so 1000% worth the investment. Get those three things right off the bat and you've got a solid, upgradable system for years to come. And that's how you over explain why to pick one PSU over another 😂
TL: DR: Yes, it's worth the investment, I'd highly recommend the TXm unit.
Well explained @Steveyg @JUNI0R
