Storage
GCUK
Hi, got my new gaming PC which came with a 500gb Samsung 970 Evo Plus M.2 and a 1TB PCS PCle M.2 SSD. Which one should I be saving my games into? I've downloaded a couple through Steam already and they are automatically saving on the 500Gb hard drive. Should I be moving them across for quicker load times etc? Appreciate any help as I'm out of touch with current PC tech.
JUNI0R
Heya! From the spec it sounds like they should be downloaded onto the 1TB PCS M.2. You'll want to keep your 500GB SSD to just Windows and applications to keep the system running as fast as possible (y)
GCUK
Thought as much. Is there a way of setting Steam to save them in the other drive or will I have to move them all across?
JUNI0R
When you download, a window will pop up and you can choose which drive they go into, you'll want to put them into the D: drive. There is a away to transfer them across once they're already downloaded but I'm away fom my PC and can't remember exactly how to do it, so I'll leave that up to someone else to explain 😂
