Hi
just recently i have noticed a problem during windows (7) updates.
i find that when my pc is doing the required reboot, it fails to start.
fans and whatever are spinning but no post beep and nothing happens.
usually i have to press the reset button for it to jump back into life.
anyway, tonight i updated my kaspersky internet security from "pure 2.0" to "pure 3.0".
install went ok, until the required reboot.
the thing shut itself down but failed to restart.
there was no "post beep" from the motherboard, nothing.
after several attempts to restart by powering down and up, still nothing.
i took the covers off the case just to make sure nothing had come unplugged.
i then gave up and borrowed my wife's laptop to search online for a solution, fully expecting to read that my motherboard was goosed.
after googling the problem i decided to try removing the ram sticks to see (hear) if there was any post beeps.
i could only remove one (of two) ram stick as the other was covered by my cpu cooler.
i then powered up the computer and it worked ok.
i then shut it down and re-fitted the ram stick, it now boots up ok again!
although it is working fine at the moment, something must have caused the failure. any ideas/advice?
thanks
Simon
thanks
Simon
