SSD question
shocksalot
Just saw that the Intel SSD's are 2.5", does this mean if you choose to get an intel SSD you have to chose a case that features a 2.5" bay?
Sounds like a stupid question but i pre-configured a system with an SSD and the Haf 922 case and the "checking your spec" popup says everyting is compatible (the haf only features 3.5 and 5.25 bays).
LinearHD
Rising Star
As SSD's have no moving parts, even if the case doesn't have brackets you can just tape the 2.5 inch drive into one of the 3.5 inch bays and you'll have no problems (apart from how messy it looks :))
Fear
awesome, just thought i'd ask =)
+rep good sir!
Always good to ask and thank for the rep ;)
Will that pass the Dhl/Yodel fragile handle with extreme care by throwing, droping, kicking and other extreme QCing some of them do to make sure everything is secure in your PC case :p
LinearHD
Rising Star
I'm sure PCS with all their might could get hold of some really strong tape xD
eagleonthelast
Don't, mine will be on it's way in the next few days, so all that care in QC will count for nothing if I'm unlucky and get a rough handler.
Fear
It's the same with all delivery companies they have a few who let them down but in the whole they are good so worry no more at these here jokes ;)
