Specs for Sibelius notation/replay program
Krzysz
Any comments welcome.
For those who don't know, the Sibelius program has some vast sound sample libraries for replaying large orchestral scores - hence the large amount of RAM. The SSD is to enable rapid loading of these libraries when the program starts. (That's how I understand it.) I'm not sure about the processor - over-specced? (Pretty certain Sibelius can't use multiple cores.)
Intel® Core™i7 Six Core Processor i7-5820K (3.3GHz) 15MB Cache
ASUS® X99-A USB 3.1: ATX, HSW-E CPU, USB 3.0, SATA 6 GB/s
64GB KINGSTON HYPER-X FURY DDR4 2400MHz (8 x 8GB)
1GB NVIDIA GEFORCE 210 - DVI, HDMI, VGA
1st Hard Disk
960GB KINGSTON V310 SSD, SATA 6 Gb (450MB/R, 450MB/W)
CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
INTEL SOCKET LGA2011 STANDARD CPU COOLER
Genuine Windows 8.1 Professional 64 Bit - inc DVD & Licence
Windows 10 Upgrade
FREE Upgrade to Windows 10 with all Windows 7 & Windows 8.1 Purchases*
DVD Recovery Media
Windows 8.1 (64-bit) Professional DVD with paper sleeve
Microsoft® Office 365 Personal (12 Month Subscription)
Monitor
Samsung SyncMaster LS27C45KBSV/EN 27"
Thanks to all you lovely people for any input!
Chris
LFFPicard
Am I to assume you will be listening to these scores all the way through loud? If so maybe a dedicated sound card would be more to your liking?
Will you be doing anything else with the machine? a GeForce 210 is very low end, if you plan on doing anything else maybe go for a low end 7 series card or mid range AMD card.
Lastly change the CPU cooler to at least the triple heat pipe cooler will help alot.
Other than that nice setup for what you need
Krzysz
Thanks for the comment.
I have a USB soundcard - the DacMagic 100, which I'm happy with. I should be able to use that.
I note what you say about the CPU cooler and the other stuff.
Thanks again.
Spuff
Expert
The latest version of Sibelius uses all the cores of a processor. It would be a very antiquated DAW if it didn't.
I think a Sibelius forum would give you a good idea of processor performance with Sibelius.
I would prefer to have a small drive as your system drive and get another SSD for data. The system drive is the one that is most likely to experience an issue where you have to wipe the drive. You don't want to have to re-load hundreds of gigs of data from an HDD or worse still DVD's.
