Specs for gaming?
hi is this okay for gta v multiplayer and pubg highest setting?
PCS SPECTRUM RGB MID TOWER CASE
ASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
128GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
2nd Storage Drive
External DVD/BLU-RAY Drive
CORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler
LED Lighting
50cm RGB LED Strip
Monitor
IIYAMA X2481HS 24" LED WIDESCREEN, D-Sub, DVI-D, HDMI 1920x1080
Monitor Cables
1 x 2 METRE HDMI (M) to DVI (M)
Razer® Ornata Chroma Gaming Keyboard
Mouse
Fnatic FLICK 2 Gaming Mouse
Gaming Mouse Pad
Cooler Master RGB Hard Gaming Mousepad
Speakers
LOGITECH Z333 2.1 SPEAKERS
Surge Protection
6 Socket 2m Surge Protector
The SSD you've selected (for Windows and programs?) is pretty pedestrian, you'll see a marked difference if you go for a faster M.2 NVMe drive for this, and the faster the better really. 128GB is doable for Windows and programs (it's what I use for example) but if you can stretch to 256GB it would be better for the future.
Do you really need a DVD writer?
I see that the above build comes in at £1735? Is that correct? As you didn't include the configurator link so we could adjust it (would be helpful if you could edit your post to include it please?), I had to manually spec it so not sure if I missed anything. Is this your maximum budget?
Is there a particular reason why you have chosen to spec a 1080 build? Not 100% certain but pretty sure the experts here could spec a decent 1440 build for the same amount (for example, I have a 1440 build which cost £1500 including the monitor).
Is there a reason why you chose the Crosshair Motherboard? I ask because you aren't using most of it's features...the X-570 would be plenty if you still wanted the RGB and is around £200 cheaper (the B450 would also be ample if you don't need the RGB and would be a further £100 cheaper).
Regardless of the build, you really should change the Wi-Fi to the Intel AX200 as it is vastly superior and only £10 more and increase the warranty to SIlver for only £5 more
I shall leave the tech advice to others but am sure they can come up with something more balanced
hi thanks for replying, its around 1533, it was supposed to be Gigabyte b450 but i cant change it since it said it was not available, so i chose my 2nd option which is the crosshair. Ill take note of that wifi intel ax2000. And i chose the1660 SUPER for thegraphics not the 1080.
do you think this is enought to install alot of games?
I would like to stretch it to 256 but i was really saving, so i just added up my hdd to 2TB, i plan to upgrade soon once i have saved up again. Actually, about the dvd writer, i was thinking about it, because of installation of some softwares etc in the future, thats why i included it?
thank you for this response, anyways
