[Spec] Gaming rig build, suggestions?
LFC908
Trying to stay around £905 but anything better/lower would be appreciated
CORSAIR CARBIDE SERIES™ 300R COMPACT GAMING CASE
AMD FX-4170 Quad Core CPU (4.20GHz/4MB CACHE/AM3+)
ASUS® M5A99X EVO R2.0 (DDR3, USB3.0, 6Gb/s,CrossFireX/SLI, Windows 8)
3GB AMD RADEON™ HD7950 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Corsair H40 Hydro Series High Performance CPU Cooler (£39)
BULLGUARD INTERNET SECURITY V2013 - 1 Year + 5GB Online Backup (£10)
vanthus
Member Resting in Peace
Nice gaming rig,you could save yourself £20 by downgrading the CPU cooler to the Triple Copper Heatpipe and if not planning on adding another 7950 in crossfire you could downgrade the motherboard to an ASUS® M5A97 R2.0(DDR3, USB3.0, 6Gb/s, Windows 8 Ready,saving another £35.Don't forget at least silver warranty for £5 though.
kruppsy
Master
I was about to post the same, you beat me! Although not listed the ASUS® M5A97 R2.0 will Crossfire though
http://www.asus.com/Motherboards/M5A97_R20/
PCS should add it to the description imo
vanthus
I'm just going by the configurator,when you select two graphics cards with this motherboard the configurator gives this message,"Unfortunately the motherboard you have selected does not support 2 graphics cards"
kruppsy
Master
Odd, I wonder why if the tech specs say its supported? Its worth knowing, I don't want to mis-inform from here on...
kruppsy
Master
I've sussed it. The 2nd PCIex16 only runs at x4 which isn't good enough for current cards in Crossfire.
Re-arrange this well known sentence 'Coat get I'll my'....
LFC908
Great thanks! Not entirely sure if I will have the funds yet but I've been wanting to build a gaming PC for two years, next month is my 18th birthday so with the money I've been saving from work and birthday money I hope I have enough hahaha
