I'm here seeking advice if this is a good spec for me
The software I plan to use includes 3ds Max and Blender for modelling, Chaos V-Ray and Corona for CPU rendering, and Chaos Vantage and Unreal Engine for GPU real-time rendering. Additionally, I use Stable Diffusion for AI upscaling, as well as the Adobe Creative Suite for post-production work. With this set of software I will need a well-balanced workstation with both strong CPU and GPU performance. Thanks in advance:
FRACTAL DEFINE 7 XL BLACK QUIET TOWER CASE
AMD Ryzen Threadripper PRO 7965WX 24 Core CPU (3.8GHz - 5.3GHz, 152MB CACHE)
ASUS® PRO WS WRX90E-SAGE SE (WRX90, ECC RDIMM, PCIe 5.0)
128GB Kingston DDR5 4800MHz ECC Registered (4 x 32GB)
32GB PALIT GEFORCE RTX 5090 GAMEROCK - HDMI, 3 x DP
512GB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
2TB Samsung 870 EVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR 1000W RMx SERIES™ ATX 3.1, MODULAR, CYBENETICS GOLD
PCS FrostFlow 200 TR4 Series High Performance CPU Cooler
1 x 10GbE + 1 x 2.5GbE ONBOARD ETHERNET PORT
MIN. 8 X USB PORTS (MOBO DEPENDENT) @ BACK PANEL + FRONT PORTS
Trusted Platform Module (TPM)
Asus TPM-SPI
Windows 11 Professional 64 Bit
Asus TPM-SPI
