Heya! Is that monitor info correct? 4K 144hz is about as high end as you can get these days and those monitors retail for about £650+ at the moment. For a PC that is capable of CPU demanding tasks as well as gaming on that monitor will really take you over your budget, unless you sacrifice rather in one of the areas.Hi all, would welcome your advice and feedback re this spec for a PC.
It will be used for 2D/3D animation by my son (large files, multiple apps at once and detailed graphics), general MS office use, surfing, and some gaming (not super heavy or much AAA).
Hes got a separate 4k 144hz monitor.
Spec based on requirements to a preferred max budget of £2000.
Do you think new spec up to the job? FYI, he's using a 5yr old ASUS ROG i7 laptop with 4 core and 16gb ram and a 9xx GPU at moment and it understandably struggles when using After Effects, Adobe suite and rendering
Thanks in advance and any recommendations welcome.
Please ignore previous post which wasn't in correct format, thank you admins for the guide.
PCS SPECTRUM RGB MID TOWER CASE
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
2TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
1TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 1880 MB/W)
Welcome Book
Logo Branding
PCSpecialist Logo
Just checked and his monitor is actually not quite as high spec its a AOC CQ32G1 32inch QHD, 144hz, 1ms, VA, AMD Freesync, (2560x1440 @144hz, 300cd/m²), he paid c.£300 about a year ago I think.Heya! Is that monitor info correct? 4K 144hz is about as high end as you can get these days and those monitors retail for about £650+ at the moment. For a PC that is capable of CPU demanding tasks as well as gaming on that monitor will really take you over your budget, unless you sacrifice rather in one of the areas.
Brilliant, that makes much more sense! Personally, I'd recommend going down the Intel route, their 12th gen CPU's are on a brand new platform and are currently the performance king. I've gone half way between the two budgets for now, I hope that's okay. If you'd like the equvalent AMD system specced up, just say, and if you have any other questions, feel free to ask!Just checked and his monitor is actually not quite as high spec its a AOC CQ32G1 32inch QHD, 144hz, 1ms, VA, AMD Freesync, (2560x1440 @144hz, 300cd/m²), he paid c.£300 about a year ago I think.
His gaming isn't super heavy on PC (mainly a PS4 and Switch).
Given that he's managed (ok barely) on his 5yr old ROG laptop till now 😁, i was sort of hoping this spec would smash it for a while at least.
I just stretched things a bit with this spwc for comparison which comes in c£2,300, slightly over budget but maybe worth it for the uplift, happy for thoughts.
Will the H150i fit in the roof of the 4000D or will PCS front mount it? I am more a fan of roof mounting than front mounting.Brilliant, that makes much more sense! Personally, I'd recommend going down the Intel route, their 12th gen CPU's are on a brand new platform and are currently the performance king. I've gone half way between the two budgets for now, I hope that's okay. If you'd like the equvalent AMD system specced up, just say, and if you have any other questions, feel free to ask!
CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE Fantastic high airflow case that looks great too
Intel® Core™ i7 12-Core Processor i7-12700KF (3.6GHz) 25MB Cache Really solid CPU from Intel's new lineup, the F variant just removes the onboard graphics you don't need anyway
ASUS® TUF GAMING Z690-PLUS WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready Solid motherboard to handle the 12700K, this one has WiFi included
32GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 16GB) Faster RAM
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR For the monitor you've mentioned, this 3060TI will be ample, especially if he doesn't plan to play too many AAA super demanding games
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE Large HDD for bulk file storage/ storing of inactive projects
2nd Storage Drive
NONE I haven't put anything here yet, but wondering if a 250GB scratch SSD might be a useful thing to have for his needs?
500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W) Dedicated super fast OS SSD for Windows and applications
1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW) Dedicated drive for games and active projects
CORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET Super high wattage PSU to allow the system to run efficently, as well as a future GPU or CPU upgrade without needing to replace the unit
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler Top end CPU cooler that'll look fantastic in the chosen 4000D
Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] I'd stick to Windows 10 for now
NO ANTI-VIRUS SOFTWARE Windows Defender is perfectly acceptable as an AV
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) Well worth the £5
Price: £2,092.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/!mHry9xuqV/
The H150i only fits front mounted in the 4000D needs to be 5000X for it to be roof mountedWill the H150i fit in the roof of the 4000D or will PCS front mount it? I am more a fan of roof mounting than front mounting.
I wouldn't pay too much attention to the pre-order status of the cards. Once you order you're put into a queue for that card and as they recieve stock they'll allocate it to orders until they have enough to cover for your card, at which point you'll likely go into build as GPU's are the thing that's holding everything up right now. None of the cards have horrible waiting times (not compared to this time last year anyway) so going for a card that's in stock generally won't save you a tonne of time. Plus, the indicators show stock at present time and by the time you come to your build, they could be complety different!Thanks guys, really appreciate the advice. I had originally specced the AMD as from my research it seemed to give fast clocking speeds (important for animation tasks) and run a little cooler (because he uses for work and play its on c. 12+ hrs per day often) than the Intel, didnt appreciate the i7 was later gen and maybe preferable. Good to know.
Re GPU, original plan was indeed Nvidia 3060 or 3060ti but chose the 3070ti based on availability at the moment (3060 pre order only) and also figured maybe bit more longevity b4 he wants to upgrade GPU or replaces monitor.
The suggested spec looks good to me, happy to take additional thoughts re the GPU and Processor.
Thanks again.
Without spending crazy money the only option PCS really has is the Cooler Master TD500, it's a really solid case and would be one of my top 3 if Corsair didn't exist 😂 It's not guaranteed that the AIO will be top mounted in any case and it's quite a struggle with the TD500, especially with RGB RAM, but it certainly is possible. If you wanted to increase the likelihood of it you could always place the order then make a request for the AIO to be top mounted with their Live Chat team. Again, it's not a guarantee, but does increase the chances.Hi again, given the comments re box size and cooling (roof/front mount) I was looking at other options but can't work out on PCS which models are suitable and give the best cooling/air flow/option for roof mounting etc for the spec suggested by JUNIOR.
Sending in a 5000X is the other option, although PCS have it for such a great price, it's difficult to not take advantage of it (I think anyway). It's about £160 from other retailers so you'd be spending about £40 over the cost of what PCS has it for. The few options you have areThanks for taking the time to help. Would you think its a better option to purchase something like a corsair icue 5000x elsewhere and send in or not worth it compared to TD500 from PCS? I think I'm pretty much set on the spec based in the suggestion.
Fair 😂 They both have their advantages and disadvantages, it's just which one you'd prefer being better, at the end of the day, it wonn't have a huge effect and both are totally fine mounting options😆😅
Haha, thanks, at the end of the day, yes its just a case and will sit under/beside a desk. The TD500 is fine from a looks perspective. I was more concerned with the most effective cooling and if that meant top mounting I thought I should go that route.
Always happy to help! Let us know what you decide on GPU and if you’re able to have get a 5000X before build!Well guys thank you for your help, especially JUNIOR. 👍
The spec is pretty much locked down apart from the GPU, PCS have advised they're unsure when the 3060, 3060ti or 3070 are going to come in at the moment "could be 2 weeks to 2 months" which obviously has a big impact on when we get it. So, still contemplating the 3070ti but know its over specced not to mention £xxx more than the best fit option.
They are also negotiating with the supplier re more Corsair 5000x cases but I'm happy to order the TD500 and could swap if the 5000x arrives before build.
Thanks again
