spec check
Slurpak
i've decided to go with this spec now:
AMD ATHLON II X4 630 (2.8GHz/2MB CACHE/AM3)
ASUS® M4N98TD EVO: DDR3, 2-Way SLI, SATA 3.0GB/s
1GB NVIDIA GEFORCE GTX465 GDDR5 PCI EXPRESS - DirectX® 11
Free Item
FREE MAFIA II Game (RRP: £34.99) with a qualifying GTX 4xx Series GPU!
640GB WD CAVIAR GREEN WD6400AARS, SATA 3 Gb/s, 64MB CACHE
Power Supply & Case Cooling
STANDARD AMD CPU COOLER
WIRELESS 802.11N 300Mbps PCI CARD (£16)
Monitor
IIYAMA E2271HDS 22" LED WIDESCREEN, HDMI/DVI-D FULL HD 1920x1080 (£149)
Logitech® Wireless Desktop® MK250 Keyboard and Mouse Combo (£19)
Standard Build - Approximately 9 to 12 working days
Price: £794.00 including VAT and delivery.
1. will this be able to handle decent games like bad company 2, css, crysis ect. at reasonably high settings?
2. do i need any extra cooling or will it be fine with the standard issued coolers?
3. the wireless keyboard and mouse combo for £19. are they any good?
4. will that PSU be suitable if i was to add another GTX465 at a later date? and also how much of a difference will adding another GTX465 have on it?
thanks in advance
Slurpak
Gorman
1. Yes
2. No extra cooling needed.
3. They are pretty standard fair, solid.
4. Yes and about 90% scaling.
Sleinous
^Yup.
HDD is a good choice as is the GPU for thing like bad company. Itll breeze though these games :)
