Spec Check
Phalanx
Hi guys,
I have just ordered the pc below, looking forward to getting it delivered but just wondered what you thought of the spec. Any constructive critism gladly taken........
PCS MAELSTROM T900 BLACK GAMING CASE (£59)
AMD PHENOM II X6 1055T (2.80GHz/9MB CACHE/AM3/)
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1GB NVIDIA GEFORCE GTX465 GDDR5 PCI EXPRESS - DirectX® 11
2nd Graphics Card
NONE
640GB WD CAVIAR BLACK WD6402AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
NONE
RAID
NONE
2nd DVD/BLU-RAY Drive
NONE
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply & Case Cooling
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER (£39)
Sound Blaster® Audigy™ SE (£25)
ONBOARD 10/100/1000 GIGABIT LAN PORT
Modem
NONE, I WILL BE USING BROADBAND
Floppy Disk Drive
NONE
Firewire & Video Editing
NONE
TV Card
NONE
Meds
Hello & welcome to the forums!
The spec looks great, everything is compatible with one another. Good choice of CPU, HDD, GPU, PSU you've obviously done your homework!
Phalanx
Thanks Meds, I thought it was a good spec for the money, but its nice to get a second opionion. You can always get a better spec machine but then you have to pay more, its a shame it works that way :D
Thanks for your post.
