Spec advice
Hi was wondering does the PCS FrostFlow 360 Series ARGB High Performance Liquid Cooler fit in the roof of LIAN LI LANCOOL 215 GAMING CASE OK?
Case LIAN LI LANCOOL 215 GAMING CASE
Processor (CPU) Intel® Core™ i9 Eight-Core Processor i9-11900KF (3.5GHz) 16MB Cache
Motherboard ASUS® ROG STRIX Z590-E GAMING WIFI (LGA1200, USB 3.2, PCIe 4.0) - ARGB Ready
Memory (RAM) 32GB Corsair VENGEANCE DDR4 3600MHz (2 x 16GB)
Graphics Card 10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP, LHR
1st M.2 SSD Drive 1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Power Supply CORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling PCS FrostFlow 360 Series ARGB High Performance Liquid Cooler
could you suggest a cooler tower that would work in that case with the Intel® Core™ i9 Eight-Core Processor i9-11900KF (3.5GHz) 16MB Cache
erm actualy it said it was compatible
Ah, ok then, that's a bug. The max it can support is 280mm actually, not 240mm
It's impossible to comment on individual components, if you list your requirements, what you're using it for, max budget and monitor you're pairing it with, then we can help. The fact your contemplating an 11900k is in itself hugely inappropriate.
Microsoft® Edge
Welcome Book
Logo Branding
PCSpecialist Logo
@Piewacket1967 if you could please stick to one thread, no need to keep opening new ones, thanks
You forgot the configuration link as in the guide linked above.
We'll also need this information, it's impossible to give any advice without it.
I have already ordered this computer so should I just cancel and get a credit note if so how do I go about it
If you cancel then the money will be returned and you can reorder.
But yes, you should definitely cancel as it's entirely the wrong platform, 11th gen are known as the worst processors in history
Hi, thanks for the advice I have changed my order. When I clicked proceed it read as compatible. I would like to use this with my MSI 1440p monitor for gaming and developing. Here is my revised order specs. please advise if you see anything wrong.
Intel® Core™ i7 Eight Core Processor i7-11700K (3.6GHz) 16MB Cache
Change to: PCS FrostFlow 240 Series RGB High Performance Liquid Cooler
Microsoft® Edge
Welcome Book
Logo Branding
PCSpecialist Logo
Microsoft® Edge
Welcome Book
Logo Branding
PCSpecialist Logo
It's the same platform, none of the 11th gen would recommended, they're out of date, extremely poor performance and expensive.
Oops sorry I forgot to paste the updated specs I have changed my order to a Intel® Core™ i7 Eight Core Processor i7-10700KF (3.8GHz) 16MB Cache. Is this ok?
You're going backwards mate! That CPU is very old now!
You need to cancel the build were now on 12th gen
JUNI0R
you don't seem to sell any 12th gen Intel cpu's though?
The configurator you're looking for is here: https://www.pcspecialist.co.uk/computers/intel-z690-pc/
As Spyder has said, it's a totally different platform so you can't put 11th gen CPU's into a 12th gen motherboard (so they've split the configurators). You might not need to cancel your order if you haven't already. We've previously found success in configuring someone a PC then having them contact PCS with the new spec as a quote then asking to transfer over to the different spec. It's slightly more leg work, but saves time as you won't need to wait for a refund and don't lose your place in the queue. That said, before we can spec any PC's, we'll need some more info
1) What's your budget?
2) What will you be using the PC for?
3) What monitor will you be using with the PC? (Either make and model or resolution and refresh rate would be ideal)
Once we have this info we'll be able to spec you a more appropriate PC for your requirements
Just to answer OP's initial question, a 360mm AIO will fit in a 215, it'll just have to go in the front instead of the top, although I'm not sure how this'd look with the varying fan sizes.
