Sound help!
PringlesInside
my pc came today :)
thank you pcs for putting 30 day trial of win7 home prem :D
Got a problem. Sound not working.
https://www.pcspecialist.co.uk/drivers/358862/
Drivers For Order Number 358862
AMD PHENOM II X6 1055T (2.80GHz/9MB CACHE/AM3/)
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1GB ATI RADEON™ HD 5750 PCI EXPRESS - DirectX® 11
640GB WD CAVIAR GREEN WD6400AARS, SATA 3 Gb/s, 64MB CACHE
Power Supply & Case Cooling
STANDARD AMD CPU COOLER
ONBOARD 10/100/1000 GIGABIT LAN PORT
Modem
NONE, I WILL BE USING BROADBAND
Standard Build - Approximately 9 to 12 working days
hmmm theres no driver links for anything :S
ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD
[/U
how i get this to produce sound? lol
PCS
Administrator
Staff member
The sound drivers are usually installed by default - no need to install them. If you can't get the sound to work then I assume it's not configured correctly. However, please check device manager first to see if there are any exclamation marks - if not, go to Control Panel --> Sound and test/configure the sound in there.
Sleinous
Yep also this, sorry forgot the 2nd possibility
PringlesInside
whats wrong with 6cores and an ati 5750 1gb????? oh umm silly question but i was thinkin pc had integrated speakers or somethin :eek: . I hav no speakers at all externally
Sleinous
Hehe, no, unless the monitor foes.
Nothing, just to me seemed a little unbalsnced - too much cpu goodness, weak gpu. AMD Phenom X4 970 + HD5850 ftw! :p
Still nice setup! Enjoy!
