Some Questions.
Ross
I can't post my specs here because I can't proceed. It says that because of my motherboard I won't be able to use the usb3.0 port and if I want it to be active then I should choose another motherboard. The thing is I don't really care about that USB port and I don't want to pay an extra £50 for a motherboard than can utilise it. There is no option to proceed unless I change the motherboard and I am wondering if there is any wY to get past this. My other question is: is the AOC 21" widescreen monitor HD? It only uses DVI cables and I don't know if that will be 1080p or not?
Rakk
The Awesome
Yes the 21.5" AOC is 1080p, whether you use DVI or HDMI (or VGA even ) it is still 1080p and will display its full resolution whichever of those cables you use.
Ross
I'm using the InWin black G7 black gaming case and the motherboard is the gigabyte 970a-d3sp
Ross
For me there is no option though. It just gives me a warning message and there are no options at the back. Is it anything to do with me being on my ipad maybe?
