A couple of questions about this machine. The "detailed specification" page is rather less helpful than the "features" page, guess I looked in the wrong place first. I found Intel's page on the motherboard, probably worth linking to as well.
I suppose, looking at the Intel product brief, that the case doesn't have an independent identification or description, so my questions about this machine are:
Thanks.
- Does the case have a fan? I presume not, and that the only moving part is the hard disk.
- Is there an external power supply with this case? I presume so.
- Is the "Maximum Supported Memory = 2GB" line on the specs page a mistake? The motherboard spec says it supports 4GB.
- If I buy the machine with 2GB does that come as 2x1GB or 1x2GB? Relevant if I want to upgrade memory later.
- I presume the machine supports USB booting (I guess these days this is a superfluous question)?
Thanks.
