Some advice please
rhodestim
Hi. Can i have some advice on the belpw spec. I haven't had a desktop pc on years and looking to treat myself. Im not really looking for advice on the spec more advice on the suitability of the components, do any stand out as being the wrong choice or are there objectiveoy better ones. Thanks
Case CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE
Processor (CPU) AMD Ryzen 7 9800X3D Eight Core CPU (Up to 5.2GHz/104MB w/3D
V-CACHE/AM5)
Motherboard GIGABYTE X870 EAGLE WIFI7 (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
Memory (RAM) 32GB Corsair VENGEANCE DDR5 6000MHz (2 x 16GB)
Graphics Card 24GB XFX RADEON™ RX 7900 XTX MERC 310 - HDMI, 3 x DP
1st M.2 SSD Drive 512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR,
4700MB/sW)
2nd M.2 SSD Drive 2TB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR,
Power Supply CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable 1 x 1.5 Metre UK Power Cable (Kettle Lead, 1.0mm Core)
Processor Cooling CORSAIR ICUE LINK H115i RGB HIGH PERFORMANCE CPU COOLER
Network Card ONBOARD 2.5Gbe LAN PORT
Wireless Network Card NONE OR ONBOARD Wi-Fi (MOTHERBOARD DEPENDENT)
USB/Thunderbolt Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT
PORTS
The two are the same thing, if you can answer the following then we have enough to be able to offer some advice
rhodestim
I dont have a monitor yet (i do have one but think i will need to upgrade but its an aoc 27inch 240hz fhd) so happy to get recomendations. Im primariky looking at gaming...my needs are to play at as high settings as possible at a decent fps but my son wants to play with as high fps as possible. He already has a 4070 which is a few years old so im looking for an upgrade on that and i was put off the 4090 and 4080 as from forums they seem they are being replaced soon. In terms of budget i can go upto £3k but only if it makes a big difference on performance, in the same vein if there is a ln option which is slightly less performance but has is significantly cheaper then i will look at that. I also wanted to know if any of the co.ponents created bottlenecks or just dont work with the rest of the build or are there components where a cheaper one will work just as well. Thanks
Ekans2011
Here's what I'd go for a top tier 1440p gaming PC.
If you merely need fps, you can go with a 7900XT (and save £150); however, if NVIDIA technologies (DLSS, RT, and FG) are important, stick with the 4070ti SUPER.
As a monitor, I suggest this AOC, which is reasonably priced and falls within your budget.
ASUS® TUF GAMING X870-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
16GB ZOTAC GEFORCE RTX 4070 Ti SUPER TRINITY BLACK EDITION - HDMI, 3 x DP
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR ICUE LINK H150i RGB HIGH PERFORMANCE CPU COOLER
Firefox™
Price: £2,553.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/3nYqRJ8QBw/
rhodestim
Thanks. What does the 5000x give above the 4000d? Would dropping the cpu to the 7800x3d make a big difference or is it a no brainer to go for the 9800? Is the image quality much better with nvidia and if so is it worth to go for the 4080 super?
Ekans2011
The 5000X is larger and is equipped with three fans.
It depends on whether you will require NVIDIA technologies. The 4080 Super, in my opinion, is not worth the money right now; we're just two months away from the next generation GPUs. A 5070 will most likely outperform the 4080 at a far cheaper cost.
