[SOLVED] Ubuntu 20.04.2 The touchpad on my Initia 15.6 does not work properly
theAlpman
Hello,
I cannot scroll using the touchpad, with 2 fingers nor on the side with one finger : it is as if I was using only one finger.
I'm working with Ubuntu 20.04.2.
Do you have an idea ? Do I need to (re)install some drivers ?
Thank you,
Regards
Initia Series: 15.6" Matte Full HD 60Hz 45% NTSC LED Widescreen (1920x1080)
Intel® Core™ i5 Quad Core Processor i5-10210U (1.6GHz, 4.2GHz Turbo)
16GB Corsair 2133MHz SODIMM DDR4 (2 x 8GB)
Integrated Intel® HD Graphics
1TB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW)
AC Adaptor
1 x 45W AC Adaptor
1 x 1 Metre Cloverleaf European Power Cable
Initia Series Integrated 36WH Lithium Ion Battery
WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
1 x USB 3.2 PORT (Type C) + 1 x USB 3.2 PORT + 2 x USB 2.0 PORTS
MULTI COLOUR BACKLIT FRENCH KEYBOARD
France/République Française - French Language
NO RECOVERY MEDIA REQUIRED
Firefox™
INTEGRATED 1MP HD WEBCAM
Chassis
Clevo NL51CU FHD (i5-10210U, FHD, 60Hz N4)
Stephen M
Cannot offer a solution but I have found Ubuntu to be a bit problematic for six or so months. Am using Manjaro more and stuff like that which was not working with Ubuntu worked out the box with Manjaro.
Also had audio problems with Ubuntu and as generally happy with Manjaro mainly use that, just check back from time to time to see what Ubuntu is like after updates.
MicFli
Is your touchpad recognised as a touchpad? i.e. what is the response to the xinput command?
If it's not recognised as a touchpad, have a look at my reply on this other thread: https://www.pcspecialist.co.uk/forums/threads/15-6-initia-amd-working-99.75939/post-552937
If it is recognised as a touchpad, what scrolling options do you have enabled? e.g. via Settings or Tweaks or using xinput set-prop...?
FWIW I have:
libinput Scroll Methods Available (318): 1, 1, 0
libinput Scroll Method Enabled (319): 0, 1, 0
which is two-finger scrolling disabled, and edge-scrolling enabled.
